Need a new handlebar - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
post #1 of 6 Old 06-18-2005, 09:25 AM
msats
I am looking for a new handlebar as mine is bend in a incident.
I am looking to reuse the barends and hand gaurds,... so its steel
can some one lead me to a solution.
Also a little straighter as the bend in my wrist used to hurt .
post #2 of 6 Old 06-18-2005, 07:00 PM
We've sold a few of these to felllow stommers and they seem to be happy.
http://www.amotostuff.com/Merchant2/...Category_Code=
Very similar to stock for height and width just not angled back quite so far.
amotostuff is offline
post #3 of 6 Old 06-18-2005, 07:28 PM
msats
One more question
how is the givi doing about the vibration as i would like to order them from you too
can you let me know
post #4 of 6 Old 07-05-2005, 09:09 PM
Kawidad's Avatar
From what I've seen in the catalogs, the ATV bars are closest to the stock bend. I would recommend aluminum over steel. Lighter, more durable, and less prone to vibration.
Kawidad
2007 DL1000K7
Kawidad is offline
post #5 of 6 Old 07-11-2005, 10:23 PM
msats
thanks ... i love it .
post #6 of 6 Old 07-12-2005, 07:23 PM
Warhammer
I've put together a gallery of some of the available options for aftermarket handlebars. You can view it here. Most prefer aluminum bars due to their strength, light weight, and lack of flex. The main challenge with them is the smaller internal diameter, meaning you'll have to get different inserts to use the barend handgueard mounts. If you go with 7/8 in bars, you can use your stock clamps. If you choose larger tapered bars, you'll also have to get clamp adapters. Personally, I like the ProTaper SE series. I'm leaning toward the CR High bend. I hope this helps.
