Custom LED turn signal mirrors - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
post #1 of 13 Old 03-26-2008, 02:45 AM Thread Starter
The Golden Monkey's Avatar
Lightbulb Custom LED turn signal mirrors
I've been working on this project off and on for a couple months, and finally finished it up. Behold, my new ultra-visible turn signal mirrors! Since I installed the flushmounts, I'd been thinking about how to set up some turn signals that can actually be seen from the front. At first I was going to put some LEDs in the handguards, until I remembered that they're the first thing to hit the ground. Also I like to remove them in the summer, so I decided on the mirrors instead.
Being the detail-oriented (some call it obsessive) guy I am, I didn't want to just glue some LEDs on the outside of the mirror housings -- I wanted them to look as "factory" as possible. Installing them in the handguards certainly would have been easier than putting them in the mirror housings -- removing the glass is not a simple task. All I can say is, I'm glad I used the cheap (~$13) Emgo napoleon-style mirrors, instead of actual napoleons...
video of rad blinky action at night
video of somewhat less rad daytime blinky action
photos of the mod process
2010 Triumph Tiger 1050se
2009 DL650A - sold
2005 DL650 - dearly departed
The Golden Monkey is offline
post #2 of 13 Old 03-26-2008, 03:12 AM
ManiacSucks's Avatar
Slick. I like them and they're a lot cheaper than the ones I've been contemplating for a year.
-Brandon-
'04 DL650 K4
'03 KLR650 A17
Previous Bikes:
'02 DL1000 K2
'96 KLR650 A10
Moderator @ [url]www.klr650.net[/url]
ManiacSucks is offline
post #3 of 13 Old 03-26-2008, 12:00 PM
Bright Side's Avatar
How did you
How did you wire the leads to power?
Bright Side
Bright Side is offline
post #4 of 13 Old 03-26-2008, 12:20 PM
LarryB's Avatar
I like the hell out of that, although they're really not that much wider than the flush mounts. Does get the blinkers away from the headlights, which is nice.
How much did you say you were charging for this mod?
[I]If you're not moving forward, you're probably in somebody's way![/I]
Current ride:
2006 Yamaha FJR1300AE, Cerulean Silver
2005 Suzuki DL1000, blue - sold
LarryB is offline
post #5 of 13 Old 03-26-2008, 03:14 PM Thread Starter
I cut the bullet connectors off the stock turn signal harness and used posi-locks to connect both the mirror and the flushmount leads to it.
2009 DL650A - sold
post #6 of 13 Old 03-26-2008, 05:02 PM
Irwin Fletcher's Avatar
I love these things. I have been looking at doing this for a long time but now that I see it I really am going to have to follow through. Where and what model of LED are you using.
Nice job on putting them in the mirror. The extra time taken makes the thing look really sharp.
Irwin Fletcher is offline
post #7 of 13 Old 03-26-2008, 07:42 PM Thread Starter
Thanks! I used the 3" light bars from Custom Dynamics (item #02241). I wanted the clear lens, but they only offer it with chrome housing, though that didn't matter since I was putting them inside the housing. I had originally planned to use individual LEDs in the handguards until I saw Drone's setup in this post on the other v-strom forum: http://11109.rapidforum.com/topic=110472265710
Getting the glass out of the mirror without breaking it was really tough. I used one of the heavier style x-acto knives to shave away the lip that retains the glass, around 3 of the corners and along the inside edge. I didn't want to take too much off though, or the glass wouldn't be secure when replaced. After soaking the housing in hot water for a few minutes I was able to ease the glass out with the help of the knife. Like I said, it's a good thing the mirrors are cheap, because I broke a couple of them. That had the plus of allowing me to refine the design somewhat. Patience will be rewarded. If I did it again, I might try cutting a slot along one of the sides to slide the glass out.
2009 DL650A - sold
post #8 of 13 Old 03-27-2008, 03:00 AM
Very nicely done. You have more patience than I do.
05 / 650 in blue
88 / KDX 200 in green
81/82 DT 175 Yamahussies
78/ GT 750 water pumper
75/Suzuki 125 RV
water warrior is offline
post #9 of 13 Old 03-17-2010, 04:23 PM
honest bob's Avatar
Very nice. Can the LED's be seen from right and left? Makes the signal stand out from the running lights. This looks like an improvement Suzuki should be contemplating.
honest bob is offline
post #10 of 13 Old 03-17-2010, 09:49 PM Thread Starter
Thanks. Those LEDs were kind of a disappointment, not being very bright unless viewed straight on. My current setup is considerably better.
2009 DL650A - sold
