Raising a 2012 Vee - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
post #1 of 3 Old 09-01-2014, 04:10 AM Thread Starter
Raising a 2012 Vee
Im looking for more ground clearance on my 2012 Vee.
Ive seen rear suspension lifting kits but what about the front end.
I thought there mite be a fork extention kit that just screws into the top of the forks.
There seams to be plenty of slack in the cables and hoses to work.
I may need to extend the side stand and centre stand but that should be the only mods that it will need I think.
Has anybody done this to a Vee??
tenterfields is offline
post #2 of 3 Old 09-01-2014, 09:57 AM
Kurgan's Avatar
First thing to figure out, especially up front, do you have the right springs in the forks for your weight?
Replacing my stock springs with 1.0 kg/mm raised the front end effectively as there was a bunch less sag. Dog bones can be added to even things out again. I don't ride offroad or try to climb over logs and stuff, but I've ridden off higher concrete curbs and such with no issues so far.
Jim
Kurgan is offline
post #3 of 3 Old 09-02-2014, 07:27 AM Thread Starter
Thanks, I will look into how much my front end sags.
