How is the Suzuki emblem attached? - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
post #1 of 9 Old 06-15-2005, 12:39 AM Thread Starter
JetJaguar's Avatar
Iím planning to do some custom paint on the cowl and I think the chrome emblem might be in the way, so Iím just wondering how it is attached in case I have to remove it. Iíve noticed in the galleries it looks like a few have taken theirs off. How is it attached, and how did you get it off? What does the panel look like underneath, any blemishes or flat spots or the like? Thanks.
JetJaguar is offline
post #2 of 9 Old 06-15-2005, 01:10 PM
TheTwins's Avatar
I think it is just stuck on, another guy said he took his off like you want to do. His had a dent hidden underneath it on one side, the other side had no dent. Sounded like someone was covering up a point of damage. I don't believe that they are supposed to be dented there.
TheTwins is offline
post #3 of 9 Old 06-15-2005, 05:16 PM
rbs_cairns
They vary. Year and model please.
post #4 of 9 Old 06-15-2005, 10:51 PM Thread Starter
JetJaguar's Avatar
It's an '05 DL650.
post #5 of 9 Old 06-16-2005, 12:21 AM
rxcoop's Avatar
hair-dryer & goo-gone....then a good wax job
rxcoop is offline
post #6 of 9 Old 06-16-2005, 11:42 AM
csr67's Avatar
Glued on
I took mine off my 05 dl650. It has some really thick adhesive. You can "roll" most of it off with your fingers, and then a bit of goo gone to remove the rest.
csr67 is offline
post #7 of 9 Old 06-16-2005, 10:12 PM
i'm the guy with the dent... :roll: i had one hell of a time getting the glue off after i removed the S. i didn't have as much trouble with the glue on the v-strom stickers. i had to buy and use stick-off. it worked pretty good. it is a citrus based product. wonder if i could have used orange juice. that is what it smelled like. they definetly tried to hide something uner the S on the right side. there was a small black spot in the paint, i think the plastic was showing through. and an area that looked like they tried to rub something out with some kind of polish or rubbing compound as the clear coat was gone. and there was a small dent in the plastic. mind you now.. this is a very small spot and easily covered up with the S. no big deal. i'll be putting another S or something over the blemish.
Kaos :wink:
Kaptain_Kaos is offline
post #8 of 9 Old 06-21-2005, 11:34 AM
Kawidad's Avatar
I took my "V-strom" stickers off and WOW, what a bear. The glue they use is about the toughest stuff I've ever run across. I got it, but holy smokes!!!!
Kawidad
2007 DL1000K7
Kawidad is offline
post #9 of 9 Old 06-24-2005, 08:51 AM
Swedge's Avatar
hmm
mine came off easy. just started at a corner and the pealed right off. i didnt like the STROM part as its reminds me too much of STROM Thurmond.. Now if they had some cool DL-1000 stickers like that for the tank...
Swedge is offline
