Turnsignal replacement - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
post #1 of 21 Old 06-14-2005, 09:24 PM
Joe Mick
My wife tired to move my 650 this morning an managed to dump it. I need to replace the brake lever and right turn signal. I am thinking about flushmount signals. Any suggestions? Will I need to drill? Thanks in advance. Joe Mc up here in Vt.
post #2 of 21 Old 06-14-2005, 11:57 PM
Wambo's Avatar
Here is some info that came handy when mine fell over and I had to replace the front turn signals. This site is good for other info as well.
http://www.motorcycleinfo.calsci.com/VStrom1.html
Lockhart Flush Mount III Turn Signals.Won't break when you tip over. Available with or without running lights. About $16.
http://www.accwhse.com/lockhart.htm#Marker%20lights
'08 SYM HD200
'07 Suzuki Bandit 1250
'06 Ducati S2R
'04 DL 650 Black-sold
'05 Buell XB9sx-sold
'04 GSXR1000-sold
'06 Triumph Tiger-sold
'06 Triumph Truxton-sold
Wambo is offline
post #3 of 21 Old 06-15-2005, 12:54 AM
JetJaguar's Avatar
I second the recommendation of the Lockhart-Phillips Flush Mount IIIís. Easy to install and look factory. You need to drill a couple of holes for mounting screws, but I preferred that to double-sided tape because here in Florida itís been my experience that accessories attached with tape tend to peel off in the heat of the sun.
- Jet Jaguar
It's not an adventure unless you need a tent, a passport, and a leather glove for your shooting hand.
'05 DL650
JetJaguar is offline
post #4 of 21 Old 06-17-2005, 12:19 AM
I just replaced my front turn signals this past week. I went with the sticky foam method only to have the one side come off after only about a week. Today, I did the drilling thing and I see no reason why they won't stay put forever...
Love this bike. It always puts a smile on my face every time I take it on the road.
Common sense is the least common of the senses.
[url]http://bertkroeker.sasktelwebsite.net/[/url]
1982 Honda CB750 Custom
2005 DL1000
Penniless Printer is offline
post #5 of 21 Old 06-20-2005, 09:50 PM
Send a message via Yahoo to Northstrom
I put the Lockhart ones I my bike as well. Drilled the holes, no big deal...and they look good. I like them better than the stock signals, but I did not really have a choice...did the vstrom drop the first week I had it. Messed up the clutch lever too, shortened it by about an inch and a half, I actually like it that way though.
2004 DL650 Black
Northstrom is offline
post #6 of 21 Old 06-24-2005, 08:30 PM
cyclerama2000's Avatar
I have to replace my front turn signals. I want running lights also. Can I just buy the dual element signals and run the 3rd wire (for the running lights) to the battery?
TIA
2004 DL650 - Blue
Yes, a DL650 can definitely do a major smokey burnout!!
cyclerama2000 is offline
post #7 of 21 Old 06-24-2005, 08:41 PM
Running lights
I just realized that won't work because the lights would be on all the time. So where do I attach the 3rd wire to?
:?: :shock:
2004 DL650 - Blue
post #8 of 21 Old 06-27-2005, 04:11 AM
Just Curious
I too have had to replace a turn signal on my DL650 (left front). I too was thinking maybe I should get flush mounts as they would look better and not break when the bike tips over (if it ever tips over again that is LOL).
Then I thought....hmmm.... that it was good that the turn signal took the damage for the fall; meaning that if I did change to flush mounts my signals would not be the sacrificial lamb of the incident. Instead of only $70.00 CDN for a new signal I may be looking at paint and body work for the side of the fairnig that the stock signal had saved.
Any thoughts?
Shawn
Strom-meister is offline
post #9 of 21 Old 06-28-2005, 12:28 PM
Kawidad's Avatar
Re: Just Curious
Any thoughts?
Shawn
Crash bars.
(Turn signals won't do anything to protect the bike)
Kawidad
2007 DL1000K7
Kawidad is offline
post #10 of 21 Old 06-28-2005, 08:47 PM
Crash bars and turn signals
Crash bars are always an excellent idea and I will order a set soon as I decide on a style and manufacturer. Thanks.
My next question is: will the typical V-Strom crash bars prevent a front turn signal from being damaged if the bike tips over. Can anyone speak from experience?
Shawn
