Installing grips over symtec heaters - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
post #1 of 28 Old 03-15-2008, 02:32 AM Thread Starter
silverstrom's Avatar
I'll soon be installing my symtec grip heaters and was wondering what is the best way to reinstall the grips. I think I read that some are spraying hair spray over the symtecs and then sliding the grips on. I guess this is supposed to help the grips slip on and when the spray dries it keeps them there. I'm looking for something quick and simple that will allow the grips to be removed if necessary . Any suggestions would be appreciated.
Thanks.
SS
DL650K7
1985 RZ500
1986 NS400R HRC
1987 RG250
1987 TZR 250
1988 RGV 250
1989 RZ 350 F2
1990 RZ 350 N2
silverstrom is offline
post #2 of 28 Old 03-15-2008, 07:17 AM
GRS1959's Avatar
Send a message via AIM to GRS1959 Send a message via Yahoo to GRS1959
I "lubricated" the inside of the grips with rubbing alcohol and slipped them back on. They haven't budged.
- Gary
Be Ashamed to Die Until You Have Won Some Victory for Humanity. ~Horace Mann
Red DL650K6
GRS1959 is offline
post #3 of 28 Old 03-15-2008, 08:25 AM
Heavy's Avatar
I used the hairspray on mine and they've been good and stable.
Make sure you find something to insulate the clutch side of the handlebar before you put the heater on. I used some insulating, pipe wrap, tape from Canadian Tire on mine.
DL1000K6
Heavy is offline
post #4 of 28 Old 03-15-2008, 08:48 AM
GRS1959's Avatar
IMHO, that is not necessary. The clutch side heater draws more power to compensate being mounted to the metal bar. If you insulate it, it would than get hotter on the clutch side. The heat on mine are even...without insulation.
- Gary
Red DL650K6
GRS1959 is offline
post #5 of 28 Old 03-15-2008, 10:14 AM
Heavy's Avatar
Whatever works. Do a search, you'll probably find a lot of people insulate the clutch side so the handlebar doesn't act like a heat sink. Which heaters are you running? I have the Symtecs and I certainly don't find the clutch side is hotter with it insulated.
DL1000K6
Heavy is offline
post #6 of 28 Old 03-15-2008, 10:21 AM
GRS1959's Avatar
I have the Symtecs, also. Have the Symtecs always had uneven power on the two heaters (with them clearly labeled 'clutch side' and 'throttle side')? Maybe they have modified the design?
- Gary
Red DL650K6
GRS1959 is offline
post #7 of 28 Old 03-15-2008, 11:18 AM
16171
The insulation is "really" only needed if one has aluminum handlebars, as it soaks up a lot more heat that the stock metal ones....according to Symtec.
post #8 of 28 Old 03-15-2008, 11:32 AM
GRS1959's Avatar
That makes sense. Thanks for clearing that up, BTD.
- Gary
Red DL650K6
GRS1959 is offline
post #9 of 28 Old 03-15-2008, 02:53 PM Thread Starter
Thanks for the help guys. It looks like hairspray is the way to go. As for insulating the clutch side, I did look into this before ordering the symtecs and they say it isn't necessary. Symtec says their grips have a design specific element wattage for each side to compensate for the lack of an insulator on the clutch side. Now, if all this snow would melt I could get on with things. The forecast for next week in Eastern Ontario is for more snow. I may need more that grip heaters to ride anytime soon.
SS
DL650K7
1985 RZ500
1986 NS400R HRC
1987 RG250
1987 TZR 250
1988 RGV 250
1989 RZ 350 F2
1990 RZ 350 N2
post #10 of 28 Old 03-16-2008, 01:55 AM
WD40 and a screw driver to get the grips off and hair spray to put them on. Very simple and very effective. Just make sure you clean the bars and the grips before reinstalling them.
leftfield123 is offline
