Bar End Screws - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
post #1 of 7 Old 03-13-2008, 11:21 AM Thread Starter
longgreensilverado's Avatar
Bar End Screws
does anyone have an idea of how long the bar end screws are on the dl650 that come with the factory hand guards? i know i can order the dl1000 bar end screws as replacements, but am looking for a length
longgreensilverado is offline
post #2 of 7 Old 03-13-2008, 01:17 PM
CT-Wee's Avatar
They're about...
|_________________________________________________ ________|
that long
DL650-k5
CT-Wee is offline
post #3 of 7 Old 03-13-2008, 01:20 PM
Sharkey's Avatar
Send a message via Yahoo to Sharkey
All you have to do is loosen the screws a couple turn, then pull the whole assembly out. Very simple. :rolleyes:
Sharkey is offline
post #4 of 7 Old 03-13-2008, 02:24 PM Thread Starter
thanks ct wee. looks like 4 3/4". i'm at work and want to order a couple screws from an online source in shelton, ct (the nutty co.)since i have alum bars and found a nice set of bar end inserts to use instead of the 5/16" fuel hose. i can't seem to tighten the bar ends to keep them from spinning.
post #5 of 7 Old 03-13-2008, 02:42 PM
CT-Wee's Avatar
I was just messin' with ya in my earlier post. :-P
But if you can't tighten the bar ends, then the nut that you are supposed to be screwing into has either fallen, or has been pushed into the handlebar. There have been a few threads on this in the past (one i've contributed to and learned from). I had to use a flashlight and a coat hangar to fish it out. Others have used an air compressor on the other end to blow it out.
https://www.stromtrooper.com/forums/s...ead.php?t=7376
https://www.stromtrooper.com/forums/s...ad.php?t=19082
DL650-k5
CT-Wee is offline
post #6 of 7 Old 03-13-2008, 03:25 PM
mtnfsh's Avatar
Another small bit of the weight assembly to watch for if you take it apart is the washer. I had a devil of a time with my left bar weight because I lost the washer that goes near the nut at the end and didn't realize it was missing until I posted my problem on another forum.
Larry
2006 V-Strom DL650
mtnfsh is offline
post #7 of 7 Old 03-19-2008, 12:35 PM Thread Starter
thanks ct wee. that was funny. i was using 5/16 hose, but didn't like the loose feeling. i bought a set of aluminum bar end expanders that i used my stock bar end screws with. works great now.
i will update w/part numbers from parts unlimited
