Staintunes with stock Heat shields - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
post #1 of 3 Old 06-08-2005, 10:26 AM Thread Starter
Swedge's Avatar
I have Kind of asked this before. But How hard would it be to Modify the Staintunes to work WITH the stock Heat shields. The Staintunes get too hot for touring with soft bags.. At least they do on my friends SV-1000.. They sound Awesome !!!
Swedge is offline
post #2 of 3 Old 06-08-2005, 11:10 AM
TheTwins's Avatar
I have an idea. Go get some huge hose clamps and some small metric nuts. I think you need three nuts and three large hose clamps. Have your local welding hillbilly weld the nuts on the hose clamps, one on each, not too far away from clamping / tightening mechanism of the clamp. This will allow you to hide the clamping / tightening mech. behind the heat shield once installed. Slide the clamp assembly over the muffler.
I'd think of something to put between the clamps and the muffler so you don't garf up the muffler surface with the sharp edges of the clamps. Like a thin layer of fiberglass mesh or something. Anyways - orient the nuts such that you can install the stock heat shield. Install it - make sure the thread depth os OK so you don't dent the muffler body by tightening the heat shield bolts. You might need a spacer or washers. Go ride.
TheTwins is offline
post #3 of 3 Old 06-08-2005, 07:24 PM
Re: Staintunes with stock Heat shields
I'm sure there is a way to make some nice looking shields for the pipes.
Yes I think they will be too hot for soft luggage. I know the left one on my bike gets hotter than the right one and the weather is still fairly cool here in the NW.
rider1951 is offline
