V-Strom 1000 Tuning Results... - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
post #1 of 14 Old 06-07-2005, 12:47 AM Thread Starter
stupolvo's Avatar
Ok, sold my VFR800 and bought a stock 2004 DL1000 with 2,500 miles in March. Like the bike, but knew that the Strom had much more lurking within than delivered by Suzuki in stock guise...
Now that the bike has been set up properly, HOLY S**T, this bike flies now! Shop who did the work is AF1 Racing in Austin, TX.
http://www.af1racing.com/dynoservices.htm
Picked up almost 25hp(!) up top and 10 ft. lbs all the way down at 3500rpm! They have done lots of tuning on all SV motors, 650 and 1000's. For whatever reason, (EPA Regs./Adventure tourer detuning?) 1st and 2nd are neutered, 4th,5th,6th are all top speed limited and completely shut down towards the top of the rev range. With Ivans TRE, Leo Vince slip-on's, K&N air filter & Suzuki TEKA fuel injection tweaking on Factory Pro Eddy-Current dyno, my Strom is a totally different bike, properly set up like it should have been delivered by the factory, with perfect throttle response and FULL power through all revs, throughout all gears.
I have also raised the forks 15mm (steers much nicer,quicker), added a Corbin seat, Windstrom shield, Pat Walsh Radar detector shelf and hard-wired my Valentine 1. Strom makes me really happy now. Really happy!
Next will add braided brake lines & pad switch for more stopping power/feel up front. Suggestions?
-Stuart in Austin
stupolvo is offline
post #2 of 14 Old 06-07-2005, 09:01 AM
senecagreen
What was the total cost of your tuning and the performance parts together? That's pretty impressive.
post #3 of 14 Old 06-07-2005, 09:28 AM Thread Starter
stupolvo's Avatar
Performance $:
Pipes were $350 used...
Ivans TRE was $100
K&N was $55
Shop charged $375 for tuning and labor.
Under a grand...
Comfort $:
Corbin $375
Windstrom $200
stupolvo is offline
post #4 of 14 Old 06-07-2005, 09:50 AM
Motornoggin
I've done similar to mine, though I have not had it dynoed yet.
TBR pipes
Ivan's TRE
Power Commander
K&N with a modified snorkle
Really runs nice! Makes a big difference! I also went up one tooth on the rear sprocket. It will pretty much loft the front wheel at will now. Pegging the speedo is no problem now either.
post #5 of 14 Old 06-07-2005, 10:10 AM
sempervee's Avatar
Yes, after I massaged and tuned Vroomhilda in properly it runs like a differetn bike and how it should behave!
I installed a Dobeck/CustomChrome Digita Fuel Optomizer (DFO) with Scorpion pipes and a tall windshield with a DayLong Russell saddle... I ride daily and I plan some nice long trips this summer!
sempervee is offline
post #6 of 14 Old 06-07-2005, 10:14 AM
Awsome
Is it possible to post the before and after Dyno results?
Thanks
"Oak tree, you're in my way"
04 1K VStrom - Kappa rack and bags, Heated grips, CRG bar end mirrors, Parabellum Windcreen, Wilber's mono shock, Corbin Smuggler seat and pillion, Hyperlights stop & Turn.
72 CB750K2&3&4 - Not much stock left
Convert is offline
post #7 of 14 Old 06-07-2005, 10:30 AM Thread Starter
stupolvo's Avatar
I have a jpg they e-mailed to me, not sure how to post it...
Also have a better dyno chart at home that I need to scan.
Shows baseline, bike with pipes & bike after tuning. Impressive.
stupolvo is offline
post #8 of 14 Old 06-07-2005, 11:27 AM
Re: V-Strom 1000 Tuning Results...
Originally Posted by stupolvo
Suggestions?
Street rubber - Stone 020's or ME880's!
Tom
Gainesville, Mo.
Current Stable:
98 Honda Valk 52,000 miles
00 BMW K1200LT 95,000 miles
02 Yamaha FZ1 23,000 miles
03 VStrom 1000 26,000 miles
04 BMW R1150RS 24,500 miles
06 Kaw ZX-6R 1,300 miles
TPadden is offline
post #9 of 14 Old 06-07-2005, 11:30 AM
jpg
You need to have the image posted somewhere like your home page or other website. Then you can link to the image using the img tag/button. I just checked and it looks like you can go to Gallery two, sign up and create an album for the images. Hope this helps.
Convert is offline
post #10 of 14 Old 06-08-2005, 07:27 AM
Swedge's Avatar
hey
does the Ivans TRE make the 6Th gear light fail to operate? like other TREs???
Swedge is offline
