Spring upgrade; How to lift the front end? - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
post #1 of 12 Old 02-29-2008, 07:33 PM Thread Starter
Juan_Banjovy's Avatar
My Sonic 1.0 fork springs arrived & I'm in the process of putting them in. Right now my old springs are out so the forks are bottomed out. I need to take weight off the front wheel to lengthen the forks enough to cram in the spacers & new springs. There's no frame to put a jack under. Can I put the jacks under the engine cases to lift the front end or will that damage it? Thanks for any help.
Blue '07 DL650
Juan_Banjovy is offline
post #2 of 12 Old 02-29-2008, 07:41 PM
Mr.Metal's Avatar
Correct me if I'm wrong, but isn't the correct process along the lines of:
1. Remove wheel
2. Remove fork
3. Take out old spring, empty out fork of old oil by "pumping it"
4. Put in new (different weight?) oil and new springs
5. Re-assemble
I'm assuming you have a centerstand? If so, you can put a jack under the bike to tilt it onto the rear wheel. Alternatively, you can attach rope to the handlebars and suspend it from your garage ceiling.
2008 DL650 a.k.a. Road Warrior, member #16 of the Flat Black Club
2009 Aprilia Tuono 1000R a.k.a. Silver Thunder
Mr.Metal is offline
post #3 of 12 Old 02-29-2008, 09:22 PM Thread Starter
OK, I've got the front wheel 2" off the ground now. How do you cram the spacers & springs onto the forks if you only weigh 250 pounds? Is there a trick to it? Just doing springs now, will have dealer do fork oil another time. Do I need to remove the front wheel & forks for this if I'm not changing the oil?
Blue '07 DL650
post #4 of 12 Old 02-29-2008, 11:40 PM Thread Starter
1. Remove wheel
2. Remove fork
5. Re-assemble
I think you're right. Looks like there's no shortcuts to doing this upgrade. Tomorrow, the front end comes off & I hope it's rideable by Monday.
Blue '07 DL650
post #5 of 12 Old 03-01-2008, 09:15 AM
Scarlett Harlot's Avatar
When we replaced mine last year the bike was on the center stand and some weight was placed on the seat and luggage rack. A jack was placed under the engine and the front came up beautifully. You can replace the springs only but changing the fork oil is easy enough to do and is an important component for getting the results you want when upgrading the suspension.
Try doing a search on this as there are many posts with lots of pictures and helpful details. The job takes about 2 to 3 hours.
'05 GL1800A-The Banana Hammock
Target fixator extraordinaire.
Never underestimate the power of stupid people in large groups. ― George Carlin
Make the world safe for stupid people and you will end up with a world full of stupid people.
Scarlett Harlot is offline
post #6 of 12 Old 03-01-2008, 12:31 PM
FastEddie's Avatar
Send a message via Yahoo to FastEddie
Do yourself a favor and buy a PitBull stand. There is a special one that lifts the front end from the steering tube, leaving you free to remove the forks from the triple clamp and do all of your rebuilding on your work bench. I bought Sonic springs and will be doing the same exercise.
06 DL650 "Big Red" brand spanking new
05 DL650 "Big Red" (totalled)
93 DR350S (sold)
"I dreamt I shot an elephant in my pajamas..."
FastEddie is offline
post #7 of 12 Old 03-01-2008, 05:18 PM
Mr.Metal's Avatar
I think my searching skills are off today, as I can't find any HOWTO/Installation threads. Does anyone have a link handy? I'm curious to see what I'll be getting myself into.
Mr.Metal is offline
post #8 of 12 Old 03-01-2008, 07:53 PM
Well Mr Metal it is not just your search skills, I can't find it either. I can't even locate my posts on how I replaced my springs. I basically followed the service manual's instructions for removing the front wheel and forks. Then it is a simple matter of unscrewing the fork caps and draining out the old oil, adding new oil and then dropping in the new springs and spacers.
I recommend the Sonic Springs as they are an excellent product and come with good instructions and some replacement washers. I used the original washers for the bottom of the springs and used the ones supplied by Sonic for the top.
If you want more details just PM me
post #9 of 12 Old 03-01-2008, 09:13 PM
FastEddie's Avatar
Make sure you loosen the top clamp on the triple clamp before you try to remove the spring cap or else there is a good chance you will bugger up the threads.
93 DR350S (sold)
post #10 of 12 Old 03-02-2008, 12:38 AM Thread Starter
Well, I got all my tools, thought it through & realized this will be much easier than I made it to be. I couldn't get the spacers & springs stuffed in because the forks collapsed when I removed the caps. I should have lifted the front BEFORE removing the caps. Bought a hoist today from Northern Tool & Appliance, but it's non-functional so I'll be exchanging it tomorrow. With that done, I'll wrap this up & be riding again.
Blue '07 DL650
