Using the Kaoko - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
post #1 of 20 Old 02-18-2008, 07:02 PM Thread Starter
whistler's Avatar
Using the Kaoko
I have got to be the biggest knucklehead :???: around for asking this, but I have to......how do I engage this thing? Installing it was no problem, and it's fully seated in the bar and everything, but I just can't seem to engage it worth a hoot.
Could somebody please describe their technique when engaging the Kaoko?
Your friendly neighborhood knucklehead,
Whistler
2019 Yamaha Tracer 900 GT (Annabelle)
2013 Suzuki V-Strom DL650 (Juliette)
2013 Yamaha FJR 1300 (Rachel)
2008 Suzuki Bandit 1250S (Fiona)
2006 Honda VFR800 (Jenny)
2005 Suzuki V-Strom DL650 (Hannah)
2003 Honda Shadow Sabre VT1100 (Veronica)
whistler is offline
post #2 of 20 Old 02-18-2008, 07:20 PM
Green427's Avatar
You need to put the beer down first, then turn the knob.....
1995 Honda CB750 - sold
2005 Honda Rebel -sold
1990 Honda PC800 -sold
2007 DL650 - sold
2011 DL650A - current
Green427 is offline
post #3 of 20 Old 02-18-2008, 07:27 PM Thread Starter
whistler's Avatar
LOL! Too funny, Bro! :-D
It's the "turning the knob" thing that throws me......do you use your pinky to roll it on, your whole hand, or what?
I know, I know - I'm a dork who's very Kaoko-challenged!
whistler is offline
post #4 of 20 Old 02-18-2008, 07:36 PM
Green427's Avatar
I don't have the throttle lock installed yet, but over at Advrider, I was told that all you have to do is use your pinkie to move the wheel 1/4 turn and the throttle will hold. Apparently we are supposed to 'calibrate' the tension before using it....don't know yet. I am sure Obi Wan Greywolf knows...let's ask him.
2007 DL650 - sold
Green427 is offline
post #5 of 20 Old 03-11-2008, 11:12 AM
Packa-strom's Avatar
This is too funny... my bike came with one of these installed, the Kaoko, not the beer... and I can't seem to use it either. Hmmm.
Packa-strom is offline
post #6 of 20 Old 03-11-2008, 07:28 PM
Heavy's Avatar
Its not a bad idea to lube the inner threads on the Kaoko. Mine started to get really tight. I took it off and there was a fair bit of rust in it. Cleaned and with a little lube it works fine again. Oh, and I use my pinky.
DL1000K6
Heavy is offline
post #7 of 20 Old 03-11-2008, 08:51 PM Thread Starter
whistler's Avatar
My pinky just ain't up to the task, I suppose. And I can't see engaging the Kaoko as a two-handed operation either (gripping the throttle with the left hand while turning the Kaoko with the right).
Ah, well . . . thanks for the info and your time.
If anyone wants a Kaoko in great shape, lemme know.
whistler is offline
post #8 of 20 Old 03-11-2008, 11:25 PM
I find it fairly easy to use. Before you even leave for a ride make sure you have it adjusted right.Adjust the "tightness" of the wheel with the small allen wrench. You want it snug enough that it won't vibrate loose when you have the cruise set. While sitting on the bike take and turn the top of your Kaoko wheel towards you until it gets close to the butt of your throttle grip. You don't want it to interfere with normal throttle action when not being used. Now pretend your are at speed and you want to use your cruise. While rolling off the throttle slide your whole hand over just enough to grip the Kaoko wheel and then roll back on the throttle and it will hold at your desired speed. Might take some practice but you will learn to really like it on those long trips.
behindbars is offline
post #9 of 20 Old 03-12-2008, 08:10 PM Thread Starter
whistler's Avatar
Now THAT makes good sense! Dude, thanks a million!
whistler is offline
post #10 of 20 Old 03-12-2008, 11:31 PM
Bright Side's Avatar
+1, I just saw this thread and agree 100% with this. I have had several bikes that I put the Kaoko on all of them. I like them and they work well for me as described above.
Bright Side
Bright Side is offline
