Synthetic - how often? - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
post #1 of 18 Old 02-01-2008, 01:24 PM Thread Starter
nec
How often do you change synthetic (Rotella) oil on DL650?
If it's more than 3.5K - do you change filter every time?
I'm trying to decide if I should stick with recommended 3.5Kmiles intervals or if using synthetic means longer interval is OK.
nec is offline
post #2 of 18 Old 02-01-2008, 01:31 PM
Canis Lupus Ridin Sicles
GrayWolf's Avatar
Send a message via Yahoo to GrayWolf Send a message via Skype™ to GrayWolf
I go 5k miles between changes. I always change my filter every time.
-GW
GrayWolf
"I wouldn't take a million dollars for the experience, but I sure wouldn't give a red cent to go through it again" -Chester Russell
2005 DL650 "Maelstrom"
2003 KLR650 "Lou"
1978 Triumph Bonneville 750 "Boomer"
Stromtrooper Offroad Club Member #3
Blue Wee-Strom Club #69
GrayWolf is offline
post #3 of 18 Old 02-01-2008, 01:41 PM
I stick to the 3500 mile interval unless I'm taking a long trip. Then I'll go up to 7000 miles on a two week trip. If I'm in 3500 mile interval mode, I'll change the oil filter every second oil change.
post #4 of 18 Old 02-01-2008, 02:27 PM
When I ran synthetic, I always changed around 4 thousand miles.
post #5 of 18 Old 02-01-2008, 02:41 PM
FireDog45's Avatar
-GW
+1. Synthetic MC specific oil and a new filter. Unless anyone can show why this is bad, I'll just keep this schedule.
Steve
09 GSA
Gone but not forgotten:
Blue 2002 Vee
08 KLR
02 ST1100
99 DR350
FireDog45 is offline
post #6 of 18 Old 02-01-2008, 02:45 PM
RedAnt's Avatar
change oil and filter every 5,000mi
-GW
+1 Same here.
The CalSci Oil guy claims it's good for 7,000mi.
I've heard a lot of claims that the OEM oil filter is MUCH better filtering than the K&R. So much so that I switched back to OEM, even though I loved the K&R welded on nut for removal. I don't know, but I've never seen much in my oil ever. I've used Rotella since mile 70, and I'm over 19000 now.
DL650K6, MadStad adj shield, Givi e45 & e36, gpsmap 76CSx, Pat Walsh skid plate & bars, Sargent seat
2004 DRZ400S
[URL="http://www.sr.unh.edu/~rea/stromtrooper/2007/Strom_Range.png"]My 2007 Range map[/URL]
RedAnt is offline
post #7 of 18 Old 02-01-2008, 03:09 PM
RedAnt's Avatar
Make the math easy.
Originally Posted by RedAnt View Post
+1 Same here.
I could easily live with 7000 miles and not worry about it. I decided on 5000 because it makes the math easy.
Do I need an oil change? = Does my odometer devide cleanly by 5000.
As cheap as the Rotella is, I'm OK with wasting 2000 miles of use. If I used the expensive MC specific oils perhaps I would feel differently.
I also do the same thing with chain oiling. My 2nd change wants to be oiled every 300 miles (The OEM one said every 600). I probably did my OEM one every 500 miles so I could use the same math to determine when it's needed. Now I have harder math since I try to oil every 333miles.
2004 DRZ400S
RedAnt is offline
post #8 of 18 Old 02-01-2008, 05:23 PM
Jblk9695's Avatar
-GW
Ditto, I didn't notice any difference in shifting or engine sounds after 5K and the old oil still looked good when I drained it, not like new but not all black and nasty looking either.
Jerry
Second childhood, heck, I'm still in the first. 72 going on 25
Added an 09 Yamaha FZ6 for my birthday
Sold the FZ6 and got a Triumph Tiger 800
Now have a Triumph Bonneville and an 09 Wee
Retired and lovin it
1945 Wife
Jblk9695 is offline
post #9 of 18 Old 02-01-2008, 06:17 PM
Send a message via AIM to coop74 Send a message via Yahoo to coop74
5K Oil & Filter Change
i change on even 5k's give or take a few. I had a beemer that i ran synthetic on and had the oil tested. The guidance from the test was that based on the wear i should be able to go 18k on that oil before needing replacement. Yes i know a beemer is dry clutch which makes a difference.
5k is plenty fine unless you do not do a lot of short or real dusty trips.
My two cents!
Coop
Robert "Coop" Cooper
03 DL1k
00 KLR650
Alcoa, TN
coop74 is offline
post #10 of 18 Old 02-01-2008, 07:08 PM
Used oil for sale...
I find that my shifting starts getting stickier at around 1500 miles or so. I've noticed it with rotella, mobil 1(cycle specific) and the amsoil that i run now. Soon as it gets noticable i change it. Goes right back to butter smooth soon as i do. No doubt the oil is good way beyond that but thats where i change it. I'm doing my best to conserve now(AL GORE said to...) as i used to change it every thou...
...someone once said it was clutch material that begins to cause that...?
JONNYREB is offline
