Givi trunk mount question - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
post #1 of 11 Old 01-25-2008, 09:19 PM Thread Starter
Greetings!
Iím looking for feedback from someone who has used the AdventureMotoStuff adjustable topcase rack. My WeeStrom came with a SW-Motech rear rack (the Alu-Rack with Givi quick-disconnect plate) that placed my Givi trunk too far forward for my wife to ride pillion. I then bought a Givi E528 plate in hopes it would give me the extra rearward adjustment on the V-Strom that it did on my Concours. Alas, it did not - trunk is in the same position as on the SWM rack
So... does the AdventureMotoStuff rack *really* let you position the trunk 2Ē more rearward then either the Givi or SW-Motech? If so Iíll probably sell the other two racks and get one. If not, I guess Iíll get busy and try to fabricate a solution on my own.
Thanks in advance for any help and advice.
Steve in Oregon
'97 Concours
'00 VFR800
'07 V-Strom 650
Mwalimu Steve is offline
post #2 of 11 Old 01-27-2008, 05:29 PM
I haven't tried the other racks, but do have the AMS rack. There are five choices for mounting position. The rear most really hangs it back a bunch. Mine is mounted in the middle position, and the whole seat is still exposed.
Moxie is offline
post #3 of 11 Old 01-27-2008, 06:18 PM
V-Tom's Avatar
You can move the case back with a simple set of plates. If you lookup "Heavy" here and PM him I am sure he will tell you what to do.
..Tom
SMIDSY detailed report.
V-Tom is offline
post #4 of 11 Old 01-28-2008, 03:32 PM
Heavy's Avatar
Originally Posted by V-Tom View Post
....lookup "Heavy" here and PM him I am sure he will tell you what to do.
..Tom
Dunno about that guy...I hear he's pretty unreliable.
DL1000K6
Heavy is offline
post #5 of 11 Old 01-28-2008, 03:36 PM
Heavy's Avatar
Originally Posted by Mwalimu Steve View Post
...Givi trunk too far forward for my wife to ride pillion....
Steve in Oregon
'97 Concours
'00 VFR800
'07 V-Strom 650
Hey Steve. Just get 2 pieces of 2" wide flat bar and you can move the GIVI back a couple of inches, easy. They say a picture is worth 1,000 words. Let me know if you have any questions.
DL1000K6
Heavy is offline
post #6 of 11 Old 01-28-2008, 03:42 PM
If I have to take my luggage rack off one more time, I'm going to get out the drill and tap set and remake the Givi mount setup.
post #7 of 11 Old 01-28-2008, 04:04 PM
Heavy's Avatar
I've been toying with the idea of an easily adjusted mount. Slide the box back for passengers then slide it forward for solo. Thinking a 6" range should be possible.
DL1000K6
Heavy is offline
post #8 of 11 Old 06-20-2011, 09:44 AM
Hi Heavy-
I am thinking of using your setup with the the v46 I just purchased. How has this worked out for you? Was there any issues with strength or bending or cracking the Givi adapter? Did you use aluminum flat bar?
Thanks,
Dave
spectda is offline
post #9 of 11 Old 06-20-2011, 09:51 AM
Hi Heavy
Got your reply to my message,
Thanks for the help and the simple solution,
-Dave
spectda is offline
post #10 of 11 Old 06-20-2011, 09:56 AM
Heavy's Avatar
I think steel is a better choice than aluminum.
The difference in weight is minimal and it would be a bitch if the box fell off, especially if you've got someone back there, relying on it as a backrest.
DL1000K6
Heavy is offline
