Why did my Stebel quit working? - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
post #1 of 11 Old 01-11-2008, 06:52 PM Thread Starter
Shredder's Avatar
It's only a few weeks old, never been in the rain. Mounted on the extra motor bolt hole with rubber dampers. Everything is connected, and the relay clicks when I hit the button. I've only hit it maybe 5 times, and it has about 50 miles on it. Any ideas?
Shredder is offline
post #2 of 11 Old 01-12-2008, 10:06 PM
Have you put a volt meter on the power supply wires at the horn - to be sure power it is getting power to the horn?
Chuck
05 DL-1000 - A farkling project in the making....
"A free people ought not only to be armed and disciplined, but they should have sufficient arms and ammunition to maintain a status of independence from any who might attempt to abuse them, which would include their own government. George Washington
cbjr0256 is offline
post #3 of 11 Old 01-13-2008, 04:38 AM
Stromtrooper.com Sponsor
Jim Davis's Avatar
The relay that comes with the Stebel horn is very poor. I've seen photos of some totally corroded inside even when new.
I would suggest getting a good quality SEALED relay.
Jim Davis, Owner, Eastern Beaver Company:
http://easternbeaver.com/ - Motorcycle Electrics: 2007 DL1000 with 16/43 gearing, Superbrace, Tokico 4 Pot fronts, BackoffXP, H4 Dual Relay Kit, PC-8 Fusepanel, 2 Powerlet Sockets, Suzuki Centerstand - 1988 Africa Twin 650, 1990 VFR 750.
Jim Davis is offline
post #4 of 11 Old 01-14-2008, 02:39 PM Thread Starter
Shredder's Avatar
Turns out it was the relay. I got another one at Advance Auto, can you point me to one of these sealed ones?
Shredder is offline
post #5 of 11 Old 01-16-2008, 07:09 AM
longgreensilverado's Avatar
my stebel quit working also, due to a blown fuse. I wired it right with the relay and made a water proof jacket for the relay. i checked all connections and wiring and can only guess i used the wrong fuse. i was using a 10amp and replaced with a 25.
longgreensilverado is offline
post #6 of 11 Old 01-16-2008, 09:06 AM Thread Starter
Shredder's Avatar
The wiring kit I got with mine had a 30 fuse in it.
Where did you put your relay? Mine's under the seat in the little tool compartment, so I know it's not subject to the weather.
Shredder is offline
post #7 of 11 Old 01-16-2008, 09:22 AM
my relay is tucked up under the fairing high up in the left corner and is water tight. maybe i was right the first time when i installed with a 30 amp fuse. i went with a 10 because i thought 30 might be too high.
post #8 of 11 Old 01-16-2008, 09:33 AM
A 20 amp fuse with 14ga wire overkill or 16ga wire being okay is the way to go. I've read reports of the current draw being in the teens. If a 30amp fuse is used, 10ga wire is needed. The fuse needs to be sized to protect the wire from overheating.
post #9 of 11 Old 01-16-2008, 09:36 AM
Eastern Beaver is a good place. It's Jim's company. See his sig.
post #10 of 11 Old 01-17-2008, 11:52 AM Thread Starter
Shredder's Avatar
Hey Jim, do you sell just the relay, not the whole kit? If you could send me a link via e-mail or PM I would appreciate it.
Rob
[email protected]
Shredder is offline
