Raising the forks - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
post #1 of 4 Old 01-09-2008, 11:43 PM Thread Starter
Raising the forks
Hello,
I very recently purchased a 2005 DL650. So far I am very happy! I have discovered, however, that the front end feels a little light. I did some searching and found that raising the rear spring preload and raising the forks in the triple tree helps. I do want to get better feel from the front end riding on the street, but I don't want to loose too much ground clearance for the dirt. I have read that the forks should be raised 15-20mm. In the interest of clearance, is 10mm a better compromise? Please, share any and all opinions. While I'm here, I'm about 150lbs...where about should fork spring preload be?
Thanks!
pehtreh is offline
post #2 of 4 Old 01-10-2008, 01:00 AM
rcacs's Avatar
I initially raised my fork tubes about 20mm, but found the bike really wanted to "fall in" to corners.
I have settled on 8mm, and find it just right for me.
You might want to consider a set of SonicSprings for the front end as well, it makes an incredible difference for not a lot of coin.
I also made a 3mm spacer for the rear spring, as I found I could not dial in quite enough preload when the bike was fully loaded for touring. I do like a fairly stiff rear-end (I'm talkin bikes here... ) for more spirited handling.
Try Rich at www.sonicsprings.com to get you set up, you will find him most helpful.
Cheers!
rcacs is offline
post #3 of 4 Old 01-10-2008, 08:27 AM
RichDesmond's Avatar
Originally Posted by pehtreh View Post
Hello,
Thanks!
Try 10mm first. I wouldn't go any more than 15mm, as after that you run the risk of the fork sliders hitting the lower triple.
Use preload to set your sag, 40mm is a good number to shoot for on the Stroms. We have a write-up on that procedure at:
http://www.sonicsprings.com/catalog/...ch_article.php
Let me know if you have any other questions.
Rich Desmond
RichDesmond is offline
post #4 of 4 Old 01-13-2008, 02:31 PM Thread Starter
Hey Rich and rcacs,
Thanks for the info and suggestions. The plan is to make those adjustments today. Rich, if I'm looking for springs in the future, I will definitely consider Sonic Springs. Thanks again!
pehtreh is offline
