What aftermarket bar is close to stock? - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
post #1 of 7 Old 01-09-2008, 09:51 PM Thread Starter
i tweaked the left bar on my wee in a recently lay-down. i would like to replace the bent bars with a stronger set of aftermarket bars. the stock bars are fine as far as riding position goes, so i would like for the new bars to feel about the same, height, angle, and pullback-wise. i would also like to be able to use the stock handguards and bar ends. what is the best choice?
thanks
chan
chanster is offline
post #2 of 7 Old 01-10-2008, 08:30 AM
longgreensilverado's Avatar
I have the protaper contour bars. they're fatter than standard bars and require clamps that drop into the stock tripple clamp. the wole set up is around 90.00. i have used protapers on other bikes and have had great luck with them. search around the forum a bit and you will see what people say about the protaper SE bars that are same diameter to the stock bars and offer a more comfortable position. when you go with aluminum bars you have to modify your inner tube hardware by filing the nuts down, since the inside dia in aluminum bars is smaller than steel.
longgreensilverado is offline
post #3 of 7 Old 01-20-2008, 10:23 AM
..You can tried MSR #11-0441.. it's almost the same...
Check here different pictures:
http://11109.rapidforum.com/topic=111077920557
garrobito is offline
post #4 of 7 Old 01-20-2008, 11:22 AM
Crazy Old Guy
fastwally's Avatar
If you like the stock bars, why don't you just put OEM bars back on?
oneidasuzuki.com have them for 47.99 I think.
It's more fun to ride a slow bike fast than to ride a fast bike slow.
K7abs
fastwally is offline
post #5 of 7 Old 01-20-2008, 01:32 PM
The ProTaper SE ATV Raptor bars are the bars that put your hands at the same location as the stock bars, but with slightly less bend (which is better for most people). See the full report here, comparing stock to the MSRs and ProTaper SE ATV Highs and Raptors:
http://11109.rapidforum.com/topic=111070173648
If you're interested in a set of the Raptors, see the classifieds:
http://11109.rapidforum.com/topic=108070008428
AtlantaMike is offline
post #6 of 7 Old 01-20-2008, 02:42 PM
Off Wee-ing in the woods
brianjonesphoto's Avatar
If you want stock bars let me know. I've got a one setting on a shelf.
03 VEE Sidecar Outfit
DL650AK7 totaled 7/24/08 21,000 miles
DL650AK7 totaled 7/24/08 5,000 Sold 12/28/17 57,800 miles
Stromtrooper offroad club #20
brianjonesphoto is offline
post #7 of 7 Old 01-20-2008, 03:31 PM
Canis Lupus Ridin Sicles
GrayWolf's Avatar
Send a message via Yahoo to GrayWolf Send a message via Skype™ to GrayWolf
Ditto, not a stock fan.
GrayWolf
"I wouldn't take a million dollars for the experience, but I sure wouldn't give a red cent to go through it again" -Chester Russell
2005 DL650 "Maelstrom"
2003 KLR650 "Lou"
1978 Triumph Bonneville 750 "Boomer"
Stromtrooper Offroad Club Member #3
Blue Wee-Strom Club #69
GrayWolf is offline
