Recommendations for heated grips?? - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
post #1 of 8 Old 01-09-2008, 11:16 AM Thread Starter
Which heated grips should I buy for my 2005 DL 1000? I did a search but found nothing conclusive for me.
Thanks!
Big & fugly, mmmmmmmm....
Long Way is offline
post #2 of 8 Old 01-09-2008, 11:55 AM
Destro's Avatar
You will find a lot of options out there, as I did myself. I opted to go with the Symtec heaters under the grips and have little to complain about. If I change anything I will add a heat controller instead of the HI/LO switch that came with it.
DESTRO
Psalm 23
DL1000 Pilot
http://my2wheels.com
For Dual Sport riders of the southwest
Destro is offline
post #3 of 8 Old 01-09-2008, 12:30 PM Thread Starter
Yeah, i'm definately on board with the heat controller. Thanks
Long Way is offline
post #4 of 8 Old 01-09-2008, 01:41 PM
K6OST's Avatar
I went with the Symtec's mounted over the stock grips and under Grip Puppies. The heat seems equal on both sides and can get pretty toasty.
A heat controller would be a nice option if you have a good place to mount it. I have the hi/low rocker switch mounted on the left fairing area and it works fine.
Without the heat controller it's really only a matter of letting your grip loosen or putting your hand out in the open air for a few seconds and any excess heat quickly dissipates.
_________________
"Old age & treachery always overcome youth & skill"
Steve - K6OST
www.dirtytires.com/forums
Motorcycle,4x4,quad,MTB forums
'07 V-Strom 650 ABS
K6OST is offline
post #5 of 8 Old 01-09-2008, 01:55 PM
BubbaGee's Avatar
Send a message via MSN to BubbaGee
I went with "Hot Grips" w/heat controller. I like the uniform heat and larger grip. The installation was very easy.
BubbaGee
2006 DL1000 in red.
"What doesn't kill you only makes you stronger."
BubbaGee is offline
post #6 of 8 Old 01-09-2008, 02:25 PM
longgreensilverado's Avatar
symtec and never looked back. casporttouring has them for 26.95, they're 30.00 with shipping
longgreensilverado is offline
post #7 of 8 Old 01-09-2008, 02:54 PM
Pondthing's Avatar
I bought the symtec from CA sport touring and plan to start the install tonight. With all the research I've done on this site, it's the biggest bang for the buck. Later I'll add the heattroller but the wife has cut me off for now...
SS
Pondthing is offline
post #8 of 8 Old 01-09-2008, 04:25 PM Thread Starter
Thanks all, I ended up buying a pair of Oxfords from the local Suzuki dealer close to me. I already installed them. Sort of variable, 4-5 settings. They work great on the spot but i look forward to riding with them asap.
Cheers!
Long Way is offline
