anyone rework stock rear shock? - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
post #1 of 4 Old 01-02-2008, 10:57 PM Thread Starter
njmaier's Avatar
I was looking to see if anyone has re-sprung and re-valved their stock rear shock? I don't quite have the money to spend on a completely new shock right now, and I'm not sure I even want to if I can get similar results by reworking the stocker. Thanks.
njmaier is offline
post #2 of 4 Old 01-03-2008, 03:25 PM
mokusbajusz's Avatar
Well, it is not the answer you are expecting, but one of our club fellow here had to let Suzuki replacing the rear shock unit under warranty due to softened spring. And an other buddy's rear unit went also wrong (adjuster knob stuck).
Both bikes are less than 2 years old and below 50 000 Kms.
Not too promising news. :???:
Balázs
DL650 K6 matt black
DL 650 info
EX-President VSCH
mokusbajusz is offline
post #3 of 4 Old 01-04-2008, 03:16 PM
Here is a link to another board section on suspension http://11109.rapidforum.com/area=83
Plenty of people have replaced the rear spring with a better quality one and are doing fine with original shock . If you are a real hard charger then a $1000 for a shock may suit you better.
Graham Downunder
graham downunder is offline
post #4 of 4 Old 01-04-2008, 08:26 PM
I had my K7 Wee shoclk reworked by AfterShocks in the San Fran bay area. I needed not to repring it. He used the oem shock because it had remote preload. Added a Penske remote resevoir and revalved the oem shock. Went from 80% preload down to 50% this is why I didn't need to add a heavier spring. Also added race tech emulators and revalved the front and added new springs. This is by far the greatest improvement of reworking the suspension on any bike I have ever owned and reworked the suspension. The cost of the rear was about a third of what a new shock would cost with the remote preload and a remote resevoir.
FJR/V-strom trooper is offline
