Rear Shock - Anything New ? - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
post #1 of 8 Old 04-19-2005, 04:30 PM Thread Starter
Send a message via Yahoo to scfrank
I searched for rear shock threads and couldn't find anything recent. So,
I put progressive springs in the forms and 10wt oil and it improved greatly. Much firmer and less wallow.
Anybody put in a penske or ohlins ? Results ? Cost ?
Thanks
Frank
scfrank is offline
post #2 of 8 Old 04-19-2005, 04:31 PM Thread Starter
That would be forks, of course !
scfrank is offline
post #3 of 8 Old 04-20-2005, 12:38 PM
SpeedStar's Avatar
Check this link:
http://11109.rapidforum.com/topic=101178641271
We have an opportunity for a group buy for Wilbers shocks for the V-strom
SpeedStar is offline
post #4 of 8 Old 04-20-2005, 12:40 PM
SpeedStar's Avatar
What fork springs did you use? I am going to be doing mine soon and have gone back and forth between a progressive and linear rate spring.
post #5 of 8 Old 05-06-2005, 09:18 AM
chrisH11
I have an '03 1000 and just did my forks. I installed the RaceTech valve kit and Traxxon Dynamics springs. It made a big improvement in the way sharp bumps are handled and the handling in general. I weigh 200lbs and used the .95kg per mm springs. The front doesn't dive near as much under braking and cornering. The bike is much more stable.
I have come to believe that the handling problems with the stock bikes is with the forks not the shock. 8)
post #6 of 8 Old 05-06-2005, 01:34 PM
SpeedStar's Avatar
Thanks Chris, I have a shock and progessive springs on order through the Wilbers group buy.
post #7 of 8 Old 05-20-2005, 09:33 PM Thread Starter
Front forks
I have progressive springs.
progressive.com
1174 I think.
scfrank is offline
post #8 of 8 Old 08-14-2005, 07:44 PM
gunnar#1
I have made the sacrafice for the 650 and sent my stock shock to Penske via traxxion dynamics and they made me a shock. It is a dream and worth the $700.
