gearing - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
post #1 of 11 Old 04-13-2005, 04:53 PM Thread Starter
gearing
Anyone have good experiences with changing the front sprocket on the 1000? Sixth gear seems useless under about 80 mph, so I was thinking about going 2-3 teeth down in the front, for some more usable torque. Bike is new, so I haven’t worked on it yet. So:
What have your changed to, and is it an easy swap? Thanx in advance… Doug.
blue 2004 1000
DCDL is offline
post #2 of 11 Old 04-13-2005, 04:59 PM
Compared To What?'s Avatar
Re: gearing
Interesting......I've been thinking about going up 1 tooth on the countershaft or down maybe two on the rear because I'm always looking for one more gear (in 6th) above 80mph.
btw 2 or 3 teeth down on the front would be REAL RADICAL, not to mention shortening up the wheelbase some.
Compared To What? is offline
post #3 of 11 Old 04-15-2005, 03:40 PM
Swedge's Avatar
really
you are looking for MORE gear on a DL1000? I find it pretty much loafing along at 80!! I had thought about going down a tooth or two on the counter shaft, but then I figured and found that even loafing at 80, it still has plenty of grunt to move ya,
Swedge is offline
post #4 of 11 Old 04-16-2005, 01:46 AM
Re: really
Mine's just a little 6FIddy. . . .
not a BIG Liter bike.
I shoulda noted that in my post. . . .
post #5 of 11 Old 04-16-2005, 06:05 PM
mcmann
If you drop 1 tooth in the front (16T) you have a 6% gear reduction. A 15T would be a 13% gear reduction. You would also have a 6% & 13% Speedo & mileage error. 10k miles would indicate 11,300 miles with a 15T.
I wouldn't go below a 15T (a tighter radius causes more stress on the chain).
If the bike has enough low end - leave it stock and use 6th as an overdrive - - - 5 gears is all you need with that torque.
I guess A 15T front would be fun for 2nd gear wheelies!
Try the 16T first - should not have to drop a link.
Tom
post #6 of 11 Old 04-18-2005, 09:11 AM Thread Starter
thanx
I appreciate the comments, especially the higher mileage on the spedo. I guess I am not appreciating the extra gear (this is my first 6-speed). I am going to leave it stock for now. Thanx again for the comments, ya kept me from making a hasty swap. Doug.
blue 2004 1000
DCDL is offline
post #7 of 11 Old 04-19-2005, 07:48 PM
Warhammer
I've been toying with the idea of going to a 16-tooth on the countershaft, too. The speedo/odo error is the only thing that has been stopping me. If I change the sprocket (cheap) I'll also have to get a Yellowbox (expensive) to correct the error. Then, I'd have to choose which to correct, speedo or odo. Either can be corrected, but not both. I wonder how hard it would be to retrofit a front wheel speedo pickup (from a 650) on to a DL1000...??? I feel like 6th gear is basically useless, and even more low-end oomph would be loads of fun! :twisted:
post #8 of 11 Old 04-20-2005, 10:01 AM Thread Starter
playing around with gears
I realize what I didn't like about 6th gear. When in it at about 70 mph, it's in the 3500 rpm range. That is not a good place in the rpm range on this bike, because it tends to hick-up and surge (kind of feels like being between jets on a carb. bike.). At my 600 mile service, I am going to ask that they remap the injection to richen the mix at 3500.
To test out my thoughts, I shifted into 5th at 35mph, and the motor had plenty of power to pull under 3k. So it's not a torque issue, but an injection issue.
I am going to leave it, at least until I get that 600 mile service. Doug.
blue 2004 1000
DCDL is offline
post #9 of 11 Old 04-24-2005, 11:56 AM
Hello;
I experienced the same problem with my '05 1000, which is, 6th too high and 5th too low (for speeds in the 70-75mph range). So I went to a 16t driveshaft sprocket and it seemed to clear up the problem. I can leave it it 6th for 95% of my freeway time and not worry about upshift/downshift all the time.
I installed (had installed) a Yellowbox speedo correction device and I am set. Since the odo and the speedo are directly related, I now know how fast I am really going and how far I am really going, not to mention an accurate read on fuel mileage.
I recommend the sprocket change. It's cheap ($30 or so) and can easily be changed back if you don't like it.
Jack
Jack Roten is offline
post #10 of 11 Old 05-26-2006, 10:54 PM
Jack
Jack, did you change the sprocket yourself? If so, are there any problems/tricks to removing the cover and hydralic hose to the clutch, etc?
'06 DL1000 - Grey
'89 GSXR 1100
'85 GS550E (Suz)
'75 Yamaha MX250B
'73 Yamaha MX125
Keep your feet on the pegs and your hand on the throttle.
ChrisW123 is offline
