My Farkled Dashboard - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
post #1 of 9 Old 03-14-2014, 06:33 PM Thread Starter
blue72beetle's Avatar
I've had some people ask about what's on my dash so I thought I'd make a post and explain it all.
First, the actual metal dashboard is an Auxiliary Shelf from Rick at Adventure Tech. I cut all my own holes for the gadgets.
Auxiliary Shelves (main page) - AdventureTech, LLC.
The volt meter on the left is just a cheap one I got from Amazon. $6.89 plus shipping, can't beat that but I won't be surprised if it ever stops working.
Mini size Red LED Digital Voltmeter Volt Meter Panel 3.3-30V - Amazon.com
The Gear Position Indicator on the right is a project someone on here came up with. It was my first electronics project and after fixing a couple mistakes I made, it works great.
WhiskeyTangoHotel.Com: Suzuki V-Strom (DL1000) Gear Position Indicator Project
https://www.stromtrooper.com/general-...n-readout.html
The FuelBot (the big LCD display) is really amazing. Designed by a guy on the SV Forum, I was the first to put it on a V-Strom. It plugs into your speed sensor and taps into the 1st fuel injector and keeps track of how much fuel you use. It's super accurate and can display a bunch of info such as, distance to empty, % tank remaining, gallons remaining, avg mpg, miles. I had planned on putting one on my SV but sold the bike before I ever did. With the V-Strom having the same engine I knew it would work on one as well. It's nice to have that kind of info available since the V-Strom fuel gauge isn't the greatest. I can't wait to really start to use it when the weather gets nice.
FuelBot: Fuel Gauge and MPG Gauge for the SV650 - Anyone interested? - Suzuki SV650 Forum: SV650, SV1000, Gladius Forums
The button on the left changes the FuelBot modes and the one on the right displays the temp on the GPI.
-Andy-
-2006 DL650-
blue72beetle is offline
post #2 of 9 Old 03-14-2014, 06:46 PM
supernewf71's Avatar
looks very cool. good job
Dave
2004 vstrom 650 blue
Past bikes
1982 yamaha virago 750
1982 Honda nighthawk 750
supernewf71 is offline
post #3 of 9 Old 03-14-2014, 07:07 PM
UncleRandy's Avatar
Thanks BlueBeetle! Great picture, and your post with links is just killer. Very nice and clean install.
UncleRandy is offline
post #4 of 9 Old 03-14-2014, 10:57 PM
trapperdog's Avatar
Very nice set up. Did the FuelBot change your tach values?
'09 VEE
'07 HD SEUC
'09 ST1300P
'06 ST1300
trapperdog is offline
post #5 of 9 Old 04-17-2014, 03:25 AM
strom lurker's Avatar
With the fuelbot, did you have to alter anything from the original SV rig? Thanks.
Current Stable:
1971 Honda CB500 Cafe Racer
1974 Honda CB550
1975 Honda CB750
1981 Honda Goldwing
1993 Yamaha GTS-1000 x3
2000 Hayabusa
2003 V-strom
strom lurker is offline
post #6 of 9 Old 04-17-2014, 02:32 PM Thread Starter
The software in the FuelBot had to be changed to account for the larger tank and different front wheel size. The install was exactly the same, although I didn't hook up the tach display. I was nervous that it would harm the tach, since its different from the SV, although I really have no evidence it would hurt it. In fact, I may just try it soon, as both the SV and the DL tachs have the same divisions.
-Andy-
-2006 DL650-
post #7 of 9 Old 09-01-2014, 01:59 PM
Blue72beetle,
After seeing this thread a while back, I was amazed by the possibilities with the fuelbot. After going back and forth on whether or not this was something I needed, I went ahead and just placed my order with TeeRiver.
My fuelbot won't ship out to me until tomorrow, but I am already looking into a waterproof enclosure for the LCD screen. I really like that you have yours mounted on the dash, and I think I am going to go that route myself. Out of curiosity, did you do anything to waterproof the lcd screen? I can't really tell from picture you have shown.
I was thinking about something like a waterproof power junction box, but I'm not really sure that would work with a dash. I may end up making a custom dash/mount to get it where I want it.
Amazon Sealed Junction Box
Anyhow, if you have any more pictures of how you mounted the lcd to the dash, I would appreciate it.
As a side note, did you ever end up hooking up the tach wire? I think the lcd is going to be the primary means of looking at the data for me, but I think the instantaneous mpg display on the tach is intriguing. I'm not sure if the novelty would wear off after a while, but it looks like a neat feature.
atwater1
atwater1 is offline
post #8 of 9 Old 09-01-2014, 02:45 PM
Voltar's Avatar
Just checked out this thread.
You did a killer job on the DIY Gear Position Indicator mount. Thank for sharing; loved seeing it!
Voltar is offline
post #9 of 9 Old 09-01-2014, 07:39 PM Thread Starter
Originally Posted by atwater1 View Post
Blue72beetle,
I cut all the holes in the dash, then after I installed everything, I put a single large piece of clear packing tape over the whole thing. It pretty much water proofed it from the top side, and on the bottom side I covered any exposed connections with hot glue from a low temp hot glue gun. The LCD came enclosed in heat shrink plastic, but I cut the top half of it off so it would fit in the hole in the dash. I've been through quite a few rainstorms and everything is still working.
The bolt heads you see are what hold the lcd to the dash, 3 for the fuel bot lcd, and 2 each for the GPI and voltmeter. Don't tighten them too tight!
Haven't needed to take the dash apart yet, so I haven't hooked up the tach wire. I may do that when I put it in the house for winter storage.
I love the fuel bot. I don't even look at the stock V-Strom gauge anymore.
-Andy-
-2006 DL650-
