OK to use this sprocket ? - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
post #1 of 9 Old 04-06-2005, 11:27 PM Thread Starter
Today I found a sprocket in my garage.
It was the front sprocket I pulled off my 02 Kawasaki ZR7, it's 16 tooth.
I pulled it off the bike when it had about 4000 miles on it, i upped it to a 17T.
So I go look on Sprocket Specialists website..
Low and behold Kaw ZR7 and DL-650 (and SV) use the same sprocket number 572.
Being a cheap bastard... I get the bright idea that I could do that front sprocket mod I thought about ... for free. (DL has a 15T stock, mod up to 16)
Anyone see a problem with using a sprocket that has 4000 mile on it from another bike? It was in perfect shape when I removed it, still looks perfect..
Thanks.
Chris
04 DL-650
Have a good time, ALL the time !
Chris is offline
post #2 of 9 Old 04-07-2005, 09:33 PM
TomStromie's Avatar
Re: OK to use this sprocket ?
I resemble that remark. I would not think twice about using that sprocket--the mileage on the sprocket might just match the mileage on the DL's chain.
TomStromie is offline
post #3 of 9 Old 04-07-2005, 10:46 PM Thread Starter
Ahhh Yes
Thanks Tommy
Actually, this sprocket has LESS miles on it than the one on the bike
Team Cheap Bastard
we'll Try er out this weekend
04 DL-650
Chris is offline
post #4 of 9 Old 04-08-2005, 09:53 AM
Swedge's Avatar
ok
why? isnt the 650 geared "tall" allready?
Swedge is offline
post #5 of 9 Old 04-08-2005, 02:32 PM Thread Starter
The 650 is not as tall as the 1000.
I like it, I just think it's a little Revvey when you run through
1st, 2nd, 3rd, like when you leave a stop sign.
Bringing those RPM's down always seems to make the ride feel smoother too, it puts you in that meaty midsection longer.
Stock or modified is fine just depends on your prefernce.
04 DL-650
Chris is offline
post #6 of 9 Old 04-24-2006, 08:48 AM
cdnt48's Avatar
I'm also thinking about a 17T front sprocket. I'd like to run 70 mph at about 4500 rpm. Anyone out there running a 17T? Can you provide some rpm info?
2005 DL650
(Alaska Leather buttpad, Givi shield, Kaoko throttle lock, Madstad mount, Nelson-Rigg RTB500 tailbag & SB900 saddlebags & SP-903 tank bag, NOJ grip wraps, handguards, ThrottleRocker)
2001 SV650S
1994 RF600R
1978 Honda XL175
Former:
1982 GS650E
1978 GS1000E
1978 Honda Hawk
cdnt48 is offline
post #7 of 9 Old 04-24-2006, 09:03 AM
Chris,
I put a 16T on my Wee and just love the difference it made. Go ahead and put it on! :P
Jay
06 Suzuki DL650
94 Yamaha XV 535 Virago
80 Yamaha XS 650 Special
stromin'taylor is offline
post #8 of 9 Old 04-24-2006, 10:59 AM
mokusbajusz's Avatar
I think it depends on what you want, make the top speed higher or lower the revs on a certain speed or reduce the fuel-consumption or make the speeds "longer"?
I personally wouldn't do that.
The bike is useless at top speed due to its far from perfect aerodynamics.
The consumption is already one of the best in the class and more or less independent of the riding style.
Making longer speeds reduces the acceleration, and also the feel of the engine torque.
It would have positive impact on the speedo only.
But of course it is your choice, and de gustibus non est disputandum.
Balázs
DL650 K6 matt black
DL 650 info
EX-President VSCH
mokusbajusz is offline
post #9 of 9 Old 04-26-2006, 12:36 AM
JoeRider
I just wanted to add how much I like the 16 tooth sprocket. I was running through the gears too fast and shifting way too often. I like to ride really smooth. The 16 tooth streches out each gear very nicely.
Highly recommended!
