Redneck Highway Bars - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
post #1 of 7 Old 02-01-2014, 06:48 PM Thread Starter
cpd419's Avatar
I had some old galvanized pipe laying around off of an old trampoline that my kids had. I had two tapered pieces with a cap on each so I cut it down to 24" and drilled holes and bolted it where the old style oil cooler use to go. At least I think that is what the threaded holes were for. I notched the bolts to give them a easy shear point in case of a hard drop. I painted it with rubberized paint but it didn't do too well. I will most likely try some barbecue grill paint when it warms up some.
cpd419 is offline
post #2 of 7 Old 02-01-2014, 06:51 PM Thread Starter
cpd419's Avatar
Bolt Notched more than shown in pic
cpd419 is offline
post #3 of 7 Old 02-01-2014, 06:52 PM Thread Starter
cpd419's Avatar
Attachment point
cpd419 is offline
post #4 of 7 Old 02-01-2014, 06:53 PM Thread Starter
cpd419's Avatar
End caps. I filled the tube with foam insulation just in case it might decide to vibrate or hum. I have no idea if it helped. It didnt do either when I rode it though.
cpd419 is offline
post #5 of 7 Old 02-02-2014, 02:42 AM
Nice, but pegs should be foldable, otherwise in case of a crash or bike tipping over, the front cylinder will be destroyed.
lunatic is offline
post #6 of 7 Old 02-02-2014, 03:13 AM
+1
Or get a bashguard and bolt it to that, then at least the guard takes the hit.
I used 20mm square alloy tube that was then fixed to normal pegs that fold up when riding that I can then 'kick' down and relax on the highway.
dogdaze is offline
post #7 of 7 Old 02-02-2014, 10:42 AM Thread Starter
cpd419's Avatar
Thats why i cut grooves in the bolts between the head and the bars. I was hoping that they would act as shear pins of sort. The bolts are soft too. I only have a half inch of bolt threaded into the head and thought if they did break maybe they would just break that far in. I might have to rethink them a little.
cpd419 is offline
