Turn signals - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
post #1 of 5 Old 01-15-2014, 09:16 AM Thread Starter
Turn signals
I am planning on replacing my turn signals with aftermarket ones.
There is lots of information about doing the changeover and the types of turn signals to use.
The aftermarket signals I have have "bullet" connectors. Can you buy the Suzuki brand connectors somewhere so that I don't have to do a any more wiring than I need to?
Also, I'm not very electrically knowledgeable. Is there a name for the connectors?
2009 Suzuki V-Strom 650
2010 Suzuki GZ250 - Gone but not forgotten
[url]www.motorcycleaddiction.ca[/url]
Dave Dark is offline
post #2 of 5 Old 01-15-2014, 09:40 AM
I'm not sure, but check with Eastern Beaver Products..........he might produce a little pigtail adapter?? I know I've seen some on the internet somewhere???
www.easternvstromrally.com
mark444 is offline
post #3 of 5 Old 01-15-2014, 11:23 AM
See if "Suzuki Turn Signal Wiring Harness Connectors Adapter Plug" on eBay look right. $10 delivered. Buell turn signals are often used as replacement for Suzuki signals.
Be sure the signals you use for the front stand away from the headlights enough to get noticed by the half of the drivers who even try to notice us.
post #4 of 5 Old 01-15-2014, 11:32 AM
Stalky Tracker's Avatar
When I swapped out my rear turn signals I picked up a pair of bullet to Suzuki connectors from Lockhart-Phillips, part number 122-9654.
I see they are out of stock now.
LP USA TURN SIGNAL CONNECTORS SUZUKI/YAMAHA SINGLE FILAMENT :: MARKER LIGHT CONNECTORS :: TURN SIGNAL ACCESSORIES :: Turn Signals :: Lockhart Phillips USA
Do a Google search on "Suzuki turn signal connector" and it should turn up a couple of other vendors.
2006 Suzuki V-Strom DL650K
1986 Honda Shadow VT700C
1974 Suzuki TM-250
1965 Suzuki 80
Stalky Tracker is offline
post #5 of 5 Old 01-15-2014, 06:00 PM
Rolex's Avatar
I got mine from Ebay.
If you are going to LED turn signals you can get the LED flasher from Ebay too.
2014 V2, Snoopy
2009 Wee, Pumbaa the pig
WR450F, The Blue Postie Bike
Club Lead not Club Med.
He with the most toys wins.
Out of my depth in a puddle.
Rolex is offline
