Long Bolt for Dl650 hanguards - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
post #1 of 6 Old 01-14-2014, 05:31 PM Thread Starter
Vne
Just last week installed handguards on my Wee. Yesterday found a small ice patch resulting in a low speed drop. Obviously took out the stock turn signal and bent the hell out of the bar end, Givi engine guards saved everything else.
Research leads me to believe Suzuki does not sell the long bolt used in the kit only the short stock bolt.
Has anyone found a good aftermarket source for the bolt? I believe its a M6 x 140mm
2009 DL650 Orange, Very early start to 60K
2004 DL650 Blue (sold)
2004 GS500F (sold)
Vne = Velocity, Never Exceed. Itís an airplane thing (my other joy in life)
Vne is offline
post #2 of 6 Old 01-14-2014, 05:40 PM
Normally, it can be straightened. If not, the Glee kit eliminates the in handlebar spacer and uses a shorter screw with only the rubber expander along with the nut containing it inside the handlebar. Try that.
post #3 of 6 Old 01-15-2014, 01:37 AM
I've straightened mine out several times.
You'd have to find a specialty metric bolt house for a replacement.
post #4 of 6 Old 01-15-2014, 10:31 AM
I believe I have the long one at home. If so, I can throw it in the mail for you.
aggiengr is offline
post #5 of 6 Old 01-22-2014, 09:30 AM
long bolt
did you try one for a DL 1000, as it is longer for the hand guards, that the 650 does not come with stock.
kidkramer is offline
post #6 of 6 Old 01-22-2014, 10:14 AM
M6 x 140mm........
I can hook you up........PM coming.
www.easternvstromrally.com
mark444 is offline
