Handlebar Change...??? - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
post #1 of 15 Old 03-23-2005, 07:36 PM Thread Starter
Thumpercrazee's Avatar
I am debating on changing the handlebar on my DL1000--There is a fair amount of flex with the OEM and I like the idea of a crossbar for strength.
Any ideas?
Thanks in advance.
TC
[COLOR="Red"]07 Star Stratoliner S
'04 DL-1000 V-Strom
03 KLR 650[/COLOR]
69 Royal Enfield 750
84 Yamaha IT 490
83 Yamaha XT 550
84 Ninja 900
Thumpercrazee is offline
post #2 of 15 Old 03-23-2005, 07:56 PM
Compared To What?'s Avatar
Are the bars flexing or just moving around in the rubber mounts? The little 6Fiddy has solid mounts and I don't feel any flex at all.
Compared To What? is offline
post #3 of 15 Old 03-24-2005, 08:34 AM
jirvine
I put on some CR low MX bars w/crossbar mostly to move my body forward out of turbulance. They are a bit too low for full lock to lock but I would think the CR High bars would do it. With the Windstrom in the middle I'm usually in a comfort zone.
post #4 of 15 Old 03-27-2005, 09:22 AM
CDN_RN
Jirvine, how tall are you? I'm 6'3" and longer in the upper body. I'm looking for a similar effect. Has anybody else modded bars to get them leaning a little bit further forward? I'm theorizing this will also help with my unbelievable side buffeting issues.
post #5 of 15 Old 03-27-2005, 02:18 PM
What kind of "side buffeting issues"?
post #6 of 15 Old 03-27-2005, 08:53 PM
jirvine
I'm a tad over 6'. I have a windstrom shield at the middle height, could go one higher but them I'd be looking through it too much. It is working well, I can listen to music through the ear plugs @ 80 unless it is nasty windy. The CR Low requires some cutting of the hand grips and shortening of a bolt to clear and I still have to play with it to get full lock to lock without the mirror hitting the Windstrom, probably not an issue with narrower screens. Check the last picture http://barko1.smugmug.com/gallery/424101 I have a Ram mount for the GPS, a throttle lock, and a Ram mount for the Roady, plus an added switch for the PIAA lights and a button for the electric chain oiler. all on the poor little bars. I had to modify the bar end mounts as being aluminum bars the hole is smaller. The bars themselves are wider but i have no complaints about that. Did 1000 miles this weekend in decent comfort except the wind and the swarm of bees I cut through. The early photos in the gallery show the stock bars, the picture with the GPS and Roady are on the low bars.
post #7 of 15 Old 03-28-2005, 07:38 PM
CDN_RN
Let me preface this by saying I'm 6'3" and weigh 320lbs. I can make this bike anything I want it to at low speeds, so that's not an issue. I get side buffeting on the highway that feels as if the bikes is sliding sideways. It makes the bike feels unsafe.
My theory is that too much of my considerable weight is over the rear half of the bike, compressing the shock and causing the front end to feel loose (for lack of a better term). I have followed suggestions on how to adjust my suspension, and seen no change. Things improve slightly when I lean forward.
I think my solution is lowering the front end, and get bars that force me to lean forward. I'm about ready to sell and go back to a cruiser.
post #8 of 15 Old 03-28-2005, 08:05 PM
I "assume" you've already cranked in as much (rear) preload as you can....So I guess you are heading in the right direction by lowering the front end and trying to get your weight forward.
I noticed that when I installed my HT panniers that what side push I got in cross winds was evened out...That is the rear "sail area" with the panniers seemed more equal to the sail area of the fairing.
Good luck, Stick with the Strom!
post #9 of 15 Old 03-28-2005, 09:32 PM
jirvine
"Let me preface this by saying I'm 6'3" and weigh 320lbs"
I'm no pro at this but I would think what you need is at least a stronger spring on the rear end (the bikes). Stock was probably designed for 160 lbs. How many miles on the current shock, might be most reasonable to have it rebuilt with some valving and spring designed for you. Badlands Motors here in NM could do it as could any decent suspension tuner.
post #10 of 15 Old 03-28-2005, 09:43 PM
I did note your "size"....
Plus a passenger at say 150 or thereabouts. . . .Hmmmmm
That's always an option . . . . All I'm saying is that the bike was designed with both a rider and a passenger in mind...And I think the rear spring rate is probably up to the task. Shock valving is another matter.
I think that the load carrying capacity for the bike (650) is 453 lbs.
http://www.mcnews.com/mcn/model_eval/VStrom05B.pdf
