Heated Grip Wiring - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
post #1 of 13 Old 03-14-2005, 10:11 AM
dancarbon
Heated Grip Wiring
Hi
I fitted Oxford Hot Grips recently and wired them straight across the battery but would like to put them on a switched feed so I can't leave them switched on and fry the battery, can anyone suggest a reliable point to tap into that won't cause any dilemas.
DC
post #2 of 13 Old 03-14-2005, 10:38 AM
Vstromper's Avatar
I haven't done it but I read elsewhere on this forum that you can tap into the factory accessory heated grip plug with a horn feed wire available from your dealer. Evidently the horn and heated grip plugs are the same.
Look back through the older heated grip posts for more details.
k
Peace carries a big gun!
www.k-diggityrides.blogspot.com
'04 1k Blue
Vstromper is offline
post #3 of 13 Old 03-14-2005, 11:08 AM
I've tapped into the headlight circuit for heated grip installation on several bikes--no problems.
moto_potato is offline
post #4 of 13 Old 03-14-2005, 01:34 PM
I tapped into the heated grip connector and wired that in to a relay, which got power from the battery. I then run all the accessories, including the heated grips, off the relay.
tedder is offline
post #5 of 13 Old 03-14-2005, 02:12 PM
Ed Woods
As long as you're using a relay, you can tap into just about any wire that becomes live when the ignition is on. The taillight is one I've used before.
Paul
post #6 of 13 Old 03-15-2005, 03:21 PM
pif
I wanted to tap them on one of the light wire but since I located the accessoirie plug behind the radiator, I had to use it. So I bought the wire lead horn from the dealer, waited 2 weeks to get it but everything was a breeze to install and look clean.
Pif.
post #7 of 13 Old 03-23-2005, 08:42 AM
dancarbon
Cheers fellas, I'll look into this accessory plug socket I think.
DC
post #8 of 13 Old 03-27-2005, 09:57 PM
The beauty of wiring into the factory plug is that the circuit is already fuse protected and switched with the ignition. You can't possibly kill the battery by leaving the grips on when it's wired that way
I would strongly suggest you also use the fuse that comes with the Hot Hands too.
Ride well and with warm mitts.
Jeff
'06 DL-1000
'06 KLX 250S (more fun than people should be allowed to have)
'72 SL-350 K2 (bump start only)
'72 CL-350 (on injured reserve list at this time)
I guess it's better to bend a valve in Missoula than to lose your mind in Bozeman.
-Barb Egan
MWValley is offline
post #9 of 13 Old 03-30-2005, 12:11 AM
DooFighter
Does anyone have the p/n for this accessory lead I need to plug into the heated grip circuit?
post #10 of 13 Old 03-30-2005, 12:14 AM
you want the horn plug wire: 36852-06G00. It's about $8.
tedder is offline
