Headlight Relay - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
post #1 of 3 Old 03-05-2005, 05:12 PM
Ed Woods
Headlight Relay
Hi,
I've got a 'Headlight Gizmo' http://www.bike-gizmos.com/bikegizmo...ght-gizmo.html that I've remove from my old bike, and want to fit to my 02 Strom (1000).
Does anyone know where the headlight relay is located? (I take it the bike uses a relay for the twin lights)
Thanks
Paul
post #2 of 3 Old 03-05-2005, 09:52 PM
Ed Woods
Okay, I've found the headlight wire that feeds into the fuse box.
But I need to locate the wire from the neutral switch, and tap into it, and I don't have a wiring diagram.
I can't even find the bloody neutral switch! Given that the gear position is monitored (O/D light, speed limiter in 5th & 6th), is there an actual neutral switch, or is it detected by the computer? Anyone know what colour the wire is, and where it is located?
Not sure about the Strom, but with most bikes (incl. Hondas) the neutral switch earths the wire.
post #3 of 3 Old 03-05-2005, 11:02 PM
mark30pwr
Check the bottom part of this page. You might find your answer there.
http://www.mikeschinkel.com/Motorcycles/V-Strom/
