Cruise Control - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
post #1 of 13 Old 03-01-2005, 09:09 PM
Der Strom
Cruise Control
I recently installed a AUDIOVOX cruise control unit in my wee strom, following the the instructions posted by Roy Bertalotto.
I must say I am very pleased with the result. It went in fairly easy, in about 3-4 hours. Though I must say I had to strip most of the fairings off the bike.
The cruise control works excellent. It worked first try, exactly like the one in my car. You can't tell it's in the bike, except for the little control buttons on the left handlebar.
Cost was about $100.
Hats off to Roy for doing all the R & D on this!
post #2 of 13 Old 03-01-2005, 09:13 PM
jirvine
How does it disengage? Brakes, clutch?
post #3 of 13 Old 03-01-2005, 09:20 PM
Der Strom
It disengages if you shut it off, engage the clutch, or brake. It has coast and accelerate functions too. I was playing with it tonight, and it maintains speed on hills real good too. I took my throttle lock and threw it away, this is way better, man.
post #4 of 13 Old 03-01-2005, 10:59 PM
jirvine
sounds like something I must do! The instructions are?? Thanks
post #5 of 13 Old 03-01-2005, 11:17 PM
Der Strom
There's photos in a different post under the same topic, authored by Roy Bertalotto. I see you asked him for the instructions on this in January. Its the same installation as i did, Roy did all the R & D for us. He has posted photos, and will give out the instructions on request.
I did mine a little different than he did, but its the same basic idea. I utilized the factory wiring for the grip heater for power and ground connections on the cruise unit. And I placed my actuator unit a little differently. And I put my vacuum reservoir under the rear fuel tank bracket.
I think the trickiest part was attaching the actuator to the throttle linkage. You have to drill a small hole in the top of the throttle stop, cut some threads in the hole with a tap tool, and install a screw. Make sure you have the right tools on hand before you start! (I spent about 15 bucks on a tap and T-handle).
If you run into any problems, message me and I will help you out.
post #6 of 13 Old 03-02-2005, 07:59 AM
jirvine
Thanks, after I posted I remmbered that I do have his instructions out in the garage. Sounds like a very good option.
post #7 of 13 Old 10-22-2005, 08:56 AM
To Der Strom,
I am new to this but have had my V-Strom for over a year now. I have sent a message to Roy asking for his detailed instructions but maybe I am to late now get them. Do you still have them electronically that you send to me. I am going to do this. My only question is to whether to purchase the AudioVox vacuum canister or make one myself out of PVC pipe connections.
Thank you so much for your helpful points about your installation!
WRichStrom is offline
post #8 of 13 Old 10-22-2005, 12:09 PM
wingman's Avatar
Rich,
Here is Roy's site pictures that will walk you through the installation http://public.fotki.com/Rbertalotto/.../cruise10.html
Enjoy,
Wingman
2001 GL1800 Blue
2005 DL650 Red
wingman is offline
post #9 of 13 Old 04-28-2006, 10:34 PM
Originally Posted by wingman
Rich,
Enjoy,
Wingman
Hey there. Anyone happen to have Roy's instructions for installing an Audiovox? (link is broken) (And Roy, I'll send you a PM in a minute.
~Geoff
Love my '04 DL1000
(but still miss my '00 Monster 750)
"Never underestimate the power of stupid people in large groups." -Steven Wright
L*F*A is offline
post #10 of 13 Old 05-01-2006, 10:43 AM
BlueLghtning's Avatar
Send a message via AIM to BlueLghtning Send a message via MSN to BlueLghtning Send a message via Yahoo to BlueLghtning
+1, I'm interested too.
Mine: KTM 650 ADV Katuki, 09 DL650, 08 Husky TE610, 08 WR250R
Hers: 07 Ninja 650R, 13 CRF250L
BlueLghtning is offline
