BT020 160? - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
post #1 of 7 Old 02-20-2005, 05:04 PM Thread Starter
BT020 160?
Just curious. Has anyone stepped up to the 160 Battleaxe on their stock rim? I'm sure swingarm clearance isn't an issue, but was wondering if the rim is. This tire performed very well for me on my other bike, and since my DL will be seeing 95% pavement, I will probably be transplanting a set after my stock rear's kaput. I want to make sure the extra rubber will fit and not slide off the back :shock: in my first corner.
Thanks!
"Ignorance is bliss"
DL-ayed is offline
post #2 of 7 Old 02-26-2005, 11:17 AM
Flyingyogi
It should fit, since some strommers are running ME880s on their bike which are 160/17-17. The only concern is that it will raise the bike a little more.
post #3 of 7 Old 03-03-2005, 08:48 PM
I put a 150 bto20 on my bike after noting that bridgestone recommends a rim wider than the strom's for a 160.
Steve
Steve strom is offline
post #4 of 7 Old 03-03-2005, 08:54 PM
MNwilly
I think you would be happier with the 150 if you are planning on staying with the 110 in front. The 160 will more than likely make the steering heavier. This is why you see guys switching from the stock 190/50 to 180/55 or 190/55 on sportbikes.
post #5 of 7 Old 03-03-2005, 09:11 PM
Velociraptor
I'll let you know since a 160 should show up on my front porch tomorrow :shock:
post #6 of 7 Old 03-03-2005, 09:51 PM
MNwilly
Is this the same Velociraptor from Speedzilla? Do you still have an RC?
post #7 of 7 Old 03-03-2005, 11:49 PM
Velociraptor
Yep, I'm the same guy. My RC51 is track only now.
