Brake Pads... - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
post #1 of 14 Old 07-06-2007, 08:21 PM Thread Starter
Brake Pads...
What brake pads would y'all recommend as a stock-replacement? I've heard the stock Strom pads described as "wooden," even though the brakes are a radical upgrade from the BMW Airhead that I rode for years.
Thanks for your input!
Fourvalve is offline
post #2 of 14 Old 07-06-2007, 08:23 PM
Maniac's Avatar
I've always had good luck with EBC sintered metal pads. They offer good feel and power. They are going on my strom when the stockers get thin.
Ian S. -- Temecula, CA
04 KLR685 -- 09 F800GS --
Moderator @ [url]www.klr650.net[/url]
[url]www.pbase.com/ischoenleber[/url]
Maniac is offline
post #3 of 14 Old 07-06-2007, 11:10 PM
Heavy's Avatar
I just put on a set of the EBC "HH" pads. They seem to have better bite. I did install braided steel lines at the same time so that may have helped.
DL1000K6
Heavy is offline
post #4 of 14 Old 07-06-2007, 11:49 PM
Can anyone explain to me just what the difference between the HH and the Sintered pads are? Is one better than the other? Should I care? what comes stock?
I suspect this might be a bit of a loaded question .
thanks.
04 blue wee
sbdep is offline
post #5 of 14 Old 07-07-2007, 12:03 AM
I just had the HH installed with SS braided lines while I was having some suspension work done. What a great improvement over stock.
"What can will go wrong".
07 V-Strom 650
03 Yamaha FJR 1300
Its loaded to the max.
FJR/V-strom trooper is offline
post #6 of 14 Old 07-07-2007, 02:00 AM
Did you use SS front and rear?
2003 V - ASV C5 Levers, Univ. Solex bars, grip heaters, ktm mirrors, c.stand, SW Mo Engine grds,Two Bros, PC3, Garmin, Givi 460, tank bag, F. Extenda, BackOff, Super Brace, Elka Shock, Race Tech Gold. AWD/Mr.Ed's Moto seat mod. Dumonde Tech Racing Oil, Spider grips, Contour.
2001 KTM LC4 farkled (sold)
awd505 is offline
post #7 of 14 Old 07-07-2007, 07:51 AM Thread Starter
Ok-what SOURCE would you recommend for EBC pads?
post #8 of 14 Old 07-07-2007, 12:15 PM
No only front. I don't use rear brake that much and saw no need. didn't put them on the rear of the FJR either. Most of the guys Iknow only do front. Most of your brake fade comes from the front cuz you use them more. I put on the EBC HH from recommendations of other riders I know and the shop people who use them. Guess its like oil threads.
07 V-Strom 650
03 Yamaha FJR 1300
post #9 of 14 Old 07-07-2007, 12:34 PM
Heavy's Avatar
thanks.
The HH pads have a higher coefficient of friction than stock pads.
EBC has a blurb about sintered pads vs organic on their website.
DL1000K6
Heavy is offline
post #10 of 14 Old 07-08-2007, 01:07 AM
Did you buy ready made SS lines, and where? I will try the HH pads.
Fourvalve - I think almost every dealer that I've seen stocks EBC.
awd505 is offline
