Basic Power Outlet Installation (With Photo) - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
post #1 of 9 Old 07-04-2007, 06:25 PM Thread Starter
Newfoundlander's Avatar
Thought this might be useful to anyone wanting to install a very basic 12v power connection.
I installed a 12v, weather-proof, accessory power outlet on my DL650 this afternoon. I wanted it there to power the small air compressor I bought to store under the seat. But it's also useful for a cellphone, etc.
Patched it directly to the battery posts, with a 10 amp automotive fuse inline on the positive lead.
Here's a photo of the installation, and the compressor as it sits nice and snug in the under-seat tray...
2008 Yamaha FZ1
2009 Kawasaki KLX450R
Newfoundlander is offline
post #2 of 9 Old 07-04-2007, 06:58 PM
I hope you saw the correction on the other thread.
edit: I guess you did. I had the same outlet in my parts bin and the white wire is ground on it.
post #3 of 9 Old 07-04-2007, 07:33 PM
Send a message via Yahoo to Monterey10
Clean
A very clean set up. My stuff is crammed under the seat. I need to get your lay out.
Craig
Monterey10 is offline
post #4 of 9 Old 07-04-2007, 08:27 PM
Interesting idea. I never considered that. I'm about to install one myself but it will have to go up front for my Garmin. I'm planning to hide the outlet inside the fairing somewhere. Location TBD.
DL650K5 (Silver)
aircav is offline
post #5 of 9 Old 07-04-2007, 09:36 PM Thread Starter
Yeah, Pat...
I was glad I did the old flashlight and wire conductivity test. I guess it would have turned my compressor into a vacuum cleaner, otherwise.
:mrgreen:
2008 Yamaha FZ1
post #6 of 9 Old 07-05-2007, 04:45 AM
powerlet - where'd you get it, part number?
Nice set up, where'd ya buy that little fella?
oldwirebrush is offline
post #7 of 9 Old 07-05-2007, 07:04 AM Thread Starter
The weather-tight power socket and compressor both came from Canadian Tire.
2008 Yamaha FZ1
post #8 of 9 Old 07-05-2007, 11:48 AM
Location: Try to stay out of Toronto as much as possible
Very nice setup, Newfoundlander.
Looks like you attached the outlet to the wall of the tray? Any problems?
I bought the same compact compressor ($5) from Cdn Tire. Works well, though rather noisily, too.
So, oldwirebrush, since you're in US, you might be able to mail order. Cdn Tire does do that, but you also might want to check one of your big chain hardware/auto stores.
Wee-less in Toronto
Drifter is offline
post #9 of 9 Old 07-05-2007, 11:55 AM Thread Starter
There is a backing-plate with slots for screws on the socket, so attaching it to the tray wall was fairly easy.
It might not be the best location for someone who wants to use the outlet on the fly, however, since there's not enough clearance between the seat and the socket to leave a plug in there. Inside the tray, and sideways might be a better setup for guys wanting power on the fly.
2008 Yamaha FZ1
