Lengthening the kickstand - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
post #1 of 11 Old 07-03-2007, 03:00 PM Thread Starter
paul_g's Avatar
Am I the only one who thinks both the Wee and the Vee have wa-a-ay too much lean on the sidestand?
I've seen various ways to reduce this. Is there a simple yet secure way to lengthen the stand without welding?
TIA
2007 DL1000
paul_g is offline
post #2 of 11 Old 07-03-2007, 03:23 PM
nvr2old's Avatar
I attached a 1/4" alum. plate to the bottom. It's also a little larger and gives better support on soft surfaces.
DL-1000 L8
DL-650 K5 red(122K)
09 DRZ400
for the safety of existence.
nvr2old is offline
post #3 of 11 Old 07-03-2007, 03:49 PM
nvr2old's Avatar
Heres a photo.
DL-1000 L8
DL-650 K5 red(122K)
09 DRZ400
nvr2old is offline
post #4 of 11 Old 07-03-2007, 03:51 PM
GrayStrom's Avatar
I have my bike raised 1", and I think it's fine. The only place I have problems is on deep gravel, where any side stand would be a problem.
K7 DL650
"It is invariably saddening to look through new eyes at things upon which you have expended your own powers of adjustment."
-a former member of the "bigger bike is better" club?
GrayStrom is offline
post #5 of 11 Old 07-04-2007, 12:21 AM
Night_Wolf's Avatar
I lowered mine with Kouba Links and want to make it lean more as some places it stands up too straight
Type @ Ya'll Later
Night_Wolf
2007 DL650abs Wee Strom
VSRI 1083/MIG 2625
A Newfie & Damm Proud Of It
Night_Wolf is offline
post #6 of 11 Old 07-04-2007, 12:26 AM
Send a message via Yahoo to Monterey10
Impressed
I'm impressed with your aluminum foot never. I've been thinking about that for a few days. Does it hit anything?
Monterey10 is offline
post #7 of 11 Old 07-04-2007, 02:16 AM
nvr2old's Avatar
No, note the different angles on it that allow clearance for cornering and the main stand.
DL-1000 L8
DL-650 K5 red(122K)
09 DRZ400
nvr2old is offline
post #8 of 11 Old 07-04-2007, 08:13 AM
aps45819's Avatar
I took a dremel tool and ground out a small notch in the stand where it hits the stop. Small change allows the stand to move a little more forward and lean more
'06 DL1000 new on 1/13/06
The difference between driving a car and climbing onto a motorcycle is the difference between watching TV and actually living your life.
aps45819 is offline
post #9 of 11 Old 07-04-2007, 08:52 AM
FarmerStrom's Avatar
Use the centerstand if you think it leans too much.
I agree, it does seem like it leans WAAAYYY over when parked. When I took mine to work one day in May (85-dgree day) when I came out ofter work, the sidestand footpad had sunk into the asphalt by about 1" so I always use the centerstand after seeing that happen to the bike.
I've also tried the trick of carrying around a flattened pop can, but it can be a hassle trying to postion it just right under the sidestand pad and then take it off again as I've gotten in the habit of leaving it in gear when parking on the sidestand (yup, I've had the dreaded roll-off-the-sidestand happen to me in the first 10 days I had the thing.)
K6 DL1000 - GIVI V46, GIVI V35s and GIVI crash bars, Madstad, Murph's Brace, Pro-Taper ATV Hi bars
1981 GS650L (for sale)
1977 GS550 (first love)
FarmerStrom is offline
post #10 of 11 Old 07-04-2007, 10:15 AM
aps45819's Avatar
I agree, it does seem like it leans WAAAYYY over when parked. When I took mine to work one day in May (85-dgree day) when I came out ofter work, the sidestand footpad had sunk into the asphalt by about 1" so I always use the centerstand after seeing that happen to the bike.(
Guess you've never seen a center stand sunk in. It will require severals people to lift the bike straight up if it sinks far enough to prevent you from rolling forward off the stand.
Get a small piece of scrap AL (3"x3") drill a hole in one corner and tie a string to it long enough to tie the other end to your hand grip. You can stand up the bike and retrieve you support without having to get back off the bike, you wont forget it and ride away and that thing can get REAL hot lying on the pavement
aps45819 is offline
