ebay lowering links... are they durable? - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
post #1 of 5 Old 06-23-2007, 04:01 PM Thread Starter
GrayStrom's Avatar
I ordered a set of 1" raising links off of ebay. I installed them today, and the bike sits PERFECT for me. I can just comfortably flat-foot it now without too much extra knee-bend, with these links and the 1000 seat.
I was wondering what you all think of the durability of these links. I'm concerned that they are made of 6061 aluminum, compared to the steel links I took off. Does anyone see this as a potential problem? What about 50,000 miles down the road? I plan to keep this bike for the rest of it's life.
K7 DL650
"It is invariably saddening to look through new eyes at things upon which you have expended your own powers of adjustment."
-a former member of the "bigger bike is better" club?
GrayStrom is offline
post #2 of 5 Old 06-23-2007, 04:13 PM
I dont think they are made of alu. because if so, the "mounting" holes will ware out quite easy as soon as they get the tiniest bit of clearence.
Dutchie is offline
post #3 of 5 Old 06-23-2007, 04:45 PM Thread Starter
GrayStrom's Avatar
Yes, they are made of 6061 aluminum.
http://cgi.ebay.com/ebaymotors/SUZUK...spagenameZWDVW
K7 DL650
post #4 of 5 Old 06-23-2007, 05:29 PM
The links have no bearing surfaces so have no wear areas. They trap the inner needle bearing races. Given the information at http://www.matweb.com/search/Specifi...bassnum=MA6016 and the extra material around the holes, I don't thing they will be a problem.
post #5 of 5 Old 06-24-2007, 02:56 PM
bobosmite's Avatar
I've been using the same links for months now and haven't had a problem. There's a topic on the board somewhere that talks about the ups and downs of the 6061 aluminum links. The general concern was for off-road durability. They were cheap enough to see if you liked the new position, so now you know if it's worth buying the more expensive steel links.
2014 Suzuki DL1000
SEARCH is your FRIEND
bobosmite is offline
