Handlebar issues - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
post #1 of 21 Old 06-19-2007, 12:24 PM Thread Starter
Jester's Avatar
Handlebar issues
Ok fellow StromTroopers... I have a problem.
I changed out my handlebars to the MSR Dominators... adjusted them to what "feels" like a comfortable position but my right hand still goes numb, not falling asleep numb (no pins and needles) just a tingling numb after about 30 minutes.
I have the bar weights and handguards on, I feel virtually no vibration in the bars (especially compared to the steel stockers). I also have neoprene wraps on the grips to keep my big-ass hands from cramping up on the small diameter bars.
Thoughts?
-Jester-
2006 DL1000 - Red
"The means of defense against foreign danger historically have become the instruments of tyranny at home." -James Madison
Jester is offline
post #2 of 21 Old 06-19-2007, 12:32 PM
GrayStrom's Avatar
Give us some details on the bars... I'm not familiar with them.
I know that the CR-Lo I had on mine were causing me a lot of the same problems. I think it has to do with the straightness of the bar ends. I needed more turn-in.
I took them off this past weekend and put the stockers back on. They have never felt more comfortable.
Do you cover your clutch and brake most of the time? I think we tend to forget to account for that hand position when choosing or adjusting bars. With the straight CR bars, my wrists were always angled out because I ride convering the clutch and brake.
K7 DL650
"It is invariably saddening to look through new eyes at things upon which you have expended your own powers of adjustment."
-a former member of the "bigger bike is better" club?
GrayStrom is offline
post #3 of 21 Old 06-19-2007, 12:40 PM Thread Starter
Jester's Avatar
I have the ATV High bars... 31.5" Wide, 6.00" High, 3.94" Pull Back. They are really close to the stockers, with a better feel at the ends (the stockers always left my wrists bent, which is what I was attributing to the hand numbing).
-Jester-
2006 DL1000 - Red
Jester is offline
post #4 of 21 Old 06-19-2007, 12:47 PM
GrayStrom's Avatar
OK, have you tried adjusting your levers down some? This helped some for me.
K7 DL650
post #5 of 21 Old 06-19-2007, 12:51 PM
K6OST's Avatar
I was able to trace my hand numbing to a seam on the inside of my tour master glove that was running along the heel of the palm of my hand.
It wasn't too noticeable at first but on long rides my fingertips were asleep. I guess it was cutting off circulation ever so slightly.
Changed the gloves, problem gone.
_________________
"Old age & treachery always overcome youth & skill"
Steve - K6OST
www.dirtytires.com/forums
Motorcycle,4x4,quad,MTB forums
'07 V-Strom 650 ABS
K6OST is offline
post #6 of 21 Old 06-19-2007, 01:03 PM
bobosmite's Avatar
Same here. I was using Icon Heavy Duty gloves and they're about as comfortable as a baseball mit. When I switched to a soft pair of Olympia gloves, my hand pain went away.
<edit> You could also look at how tight your elbow pads fit. There's a nerve in your elbow that can get pinched and cause numbness in your pinky and ring fingers.
2014 Suzuki DL1000
SEARCH is your FRIEND
bobosmite is offline
post #7 of 21 Old 06-19-2007, 03:26 PM
Destro's Avatar
I would say to check out all of your riding gear also. I had a pair of glove that made my hands sleepy if I at all thought about tightening the strap on the back of the wrist. I have also found the wrist cuff on a jacket can have an effect on the awake state of your fingers also.
DESTRO
Destro is offline
post #8 of 21 Old 06-19-2007, 03:53 PM Thread Starter
Jester's Avatar
I wish equipment was the case... my test run the other day (while adjusting for position comfort) did not involve any gloves.
I have the bars positioned so that I can sit straight up (no slouch unless I want to) and arms in a relaxed, "chicken wing" capable position (loose elbows).
Funny thing, the left hand doesn't go numb. I was thinking maybe my back needs a good crack visit... but I don't numb out at all on my cruiser (except the arse).
-Jester-
2006 DL1000 - Red
Jester is offline
post #9 of 21 Old 06-19-2007, 06:37 PM
Heavy's Avatar
Are you using any sort of throttle lock/assist?
DL1000K6
Heavy is offline
post #10 of 21 Old 06-19-2007, 09:10 PM Thread Starter
Jester's Avatar
I have a throttle rocker, but it wasn't on the bike while I was adjusting the bars.
It's back on there now since it helps me flex the feeling back into my fingers while riding.
-Jester-
2006 DL1000 - Red
Jester is offline
