Bugs on the backside ..... - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
post #1 of 11 Old 06-14-2007, 08:51 AM Thread Starter
cmosentine's Avatar
OK, it's not what it sounds like. Yesterday I washed my mule (1000K6) and discovered bug guts on the backside of my windscreen. I have a Cee Bailey mounted on a Madstad bracket. I guess I must have a lot of vortices from the combination causing bugs to impact on the backside of the screen.
So what I wonder is if I have the windscreen adjusted properly or is this a normal occurrence??? I am very happy with the airflow and have very little buffeting (mostly from dirty air behind pickups and minivans).
Thanks for the help, Chris.
[U]Chris Mosentine [/U]
2008 HD FLSTF
Previous - 2006 Suzuki DL1000, 1993 Kawasaki VN750, Suzuki DL350, 1976 Yamaha DT400, 1977 Honda XR75.
cmosentine is offline
post #2 of 11 Old 06-14-2007, 09:07 AM
whistler's Avatar
I have the same condition on my vented chopped shorty. It was noteworthy at first, now it's another non-issue. If it gets too bad, I'll just spray some more flat black on the inside surface.
2019 Yamaha Tracer 900 GT (Annabelle)
2013 Suzuki V-Strom DL650 (Juliette)
2013 Yamaha FJR 1300 (Rachel)
2008 Suzuki Bandit 1250S (Fiona)
2006 Honda VFR800 (Jenny)
2005 Suzuki V-Strom DL650 (Hannah)
2003 Honda Shadow Sabre VT1100 (Veronica)
whistler is offline
post #3 of 11 Old 06-14-2007, 09:50 AM
WoodWorks's Avatar
Thumbs up Normal
It's normal. You're going to get vortices any time you hold up anything into the windstream. Even if you mounted the screen horizontally you'd get some small vortices off the trailing edge. If the buffeting is diminished, you've got it mounted right.
Just to leave one's homeland is to accomplish half the Dharma
--Milarepa
WoodWorks is offline
post #4 of 11 Old 06-14-2007, 11:14 AM Thread Starter
cmosentine's Avatar
My old bike, a Kawi 750 did not have this issue, but then again it completely blocked the air stream to the point of having the wind blow backwards onto me while riding. Talk about no buffeting. But I'll take the small amount of buffeting with the Strom anyday.
2008 HD FLSTF
post #5 of 11 Old 06-14-2007, 12:32 PM
nvr2old's Avatar
My Windstrom Manta does the same thing. The sportbikes I've had never did , but they never had an opening for air on the bottom edge.
DL-1000 L8
DL-650 K5 red(122K)
09 DRZ400
for the safety of existence.
nvr2old is offline
post #6 of 11 Old 06-14-2007, 12:36 PM
WoodWorks's Avatar
Um, maybe the bugs squished on the back of your head then. D'jever check?
--Milarepa
post #7 of 11 Old 06-14-2007, 01:45 PM Thread Starter
cmosentine's Avatar
So that's why my comb always got stuck. And here I was blaming my conditioner.
2008 HD FLSTF
post #8 of 11 Old 06-14-2007, 01:46 PM
KAP
KAP's Avatar
I have the same set up and the same thing happens. Honda wax cleaner takes care of it.
Kyle
2005 Black Vee
KAP is offline
post #9 of 11 Old 06-14-2007, 02:03 PM
I've noticed the same phenomenon. MP touring screen mounted to a Madstad bracket. Must be one heck of a vortex to slam an insect body forward with enough force to make it go splat.
650VTwin is offline
post #10 of 11 Old 06-14-2007, 10:22 PM
O-9
O-9's Avatar
the bugs are deflecting off the fairing onto the shild
The first requisite of a good citizen in this republic of ours is that he shall be able and willing to pull his own weight.
Theodore Roosevelt
O-9 is offline
