More power... - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
post #1 of 6 Old 06-02-2003, 09:31 AM
St Germain
More power...
Doesn't anyone did something to increase the power of their Strom?
I would like to avoid changing the mufflers unless one brand wouldn't be
that noisy.
St Germain :twisted:
post #2 of 6 Old 06-10-2003, 08:57 PM
john stewart
power
i first drilled a 1" hole in each exhaust.
then installed uni foam filters. 2.25 * 6" part #604
ran without the top of airbox. way to loud. i now have top back on and snorkel removed. quiet enough for now. am probably going to drill some holes in the top of the box.
increase in power. most definitly.
has not been on dyno yet, am waiting to make sure i have a way to adjust the fi box to tune for power.
total invesment so far about 60 bucks. not counting tools.
beers
post #3 of 6 Old 06-11-2003, 11:50 AM
replaced
Howboucha John!
Where did you drill the hole (exhaust) Any pics?
Brendan #653
post #4 of 6 Old 06-11-2003, 01:35 PM
hole
right down the center of the exit hole. i used 1" motul drill i got at home depot. was about 6 bucks. had to buy a quick release extention 12" to get deep enough to hit the baffle.
was a bit of work, but well worth it. sounds much better but not to loud.
pics no not really much to show. if i can get hold of a dig camera i will see what i can do.
beers
john stewart
post #5 of 6 Old 10-21-2003, 03:08 AM
motordog1
more power
I have drilled my stock exhaust to 1 inch. Sounds much better but certainly not as good as some good cans. Next I think I will try the Uni filters with the stock airbox. I hope the stock map will handle this combination.
post #6 of 6 Old 10-24-2003, 03:14 AM
SwissStromie
drill drill drill
:shock: If you just drill the exhaust , the risk is to have a loss of torque at low-mid revs, the whole engine is tunedso you should also works on the air-gas input, else it's useless ...
Perhaps it will "breathe " better at higher revs . But I suggest that you try your strom on a dyno for relevant measurements about hp and torque and not just "sound impression".
just my 5 cents :wink:
V
Weekend project - aux power Brojon DL650A - 2012-2016 1 05-02-2016 03:08 PM
Power Outlet Problem Jim Judd DL1000A - 2014-2016 8 03-22-2016 12:12 AM
Snaking power cable from GPS to Battery Harry Dresden PI DL650A - 2012-2016 7 02-16-2014 03:34 PM
Power Commander or re-gear? Power commander 3 or 5? Red5 DL1000 from 2002-2012 12 12-30-2013 07:53 PM
