Wee suspension - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
post #1 of 2 Old 06-11-2007, 05:12 PM Thread Starter
Wee suspension
After riding my Wee to the Reno gathering I noticed even with proper suspension set up some deficiencies. So off to the suspension Guru at AfterShocks in Palo Alto, Ca. in and around the San Fran area. He has done my FJR and my KLX300 this year.
He will use the original shock and spring cuz it will work. Put a spacer in the rear shock. Use a Penske remote reservoir with compression dampening. Revalve the rear shock.
He will put emulators in the front shocks, re-valve them and do a spring mod.
Also while it is in the shop he will replace the front brake lines with SS lines and put on new pads as I found the brakes a little on the soft side for my liking.
Phil is the real deal and even tries to save you money without compromising the end result.
Results to follow.
"What can will go wrong".
07 V-Strom 650
03 Yamaha FJR 1300
Its loaded to the max.
FJR/V-strom trooper is offline
post #2 of 2 Old 06-12-2007, 02:23 PM
Wee_Willie's Avatar
Sounds good Mike.... Pictures of the shock when it's done??
Willie
[url]http://www.flickr.com/photos/[email protected]/[/url]
IBA#27466
2007 Suzuki GSF1250K7 Bandit - Black of course!
2006 Suzuki DL650K6 - Alaska and back July/Aug 2007
1978 Yamaha SR500E - Frame up restoration in progress
1968 Yamaha DT1 Shorttracker / "Bargain" Craigslist find... yeah, right
Wee_Willie is offline
