Painted my wheels with 2 part epoxy.... - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
post #1 of 12 Old 06-10-2007, 06:32 PM Thread Starter
I'm not a big fan of black wheels on the V Strom. I painted the wheels on my 04 using a Groits Garage wheel paint kit. But this kit is only available in a Mercedes silver color. I found a two part epoxy system that is used extensively in the firearms industry that is VERY easy to apply. You mix the two parts, no need for reducer, and spray with a touch-up gun or an airbrush........Extremely hard finish. I test sprayed a piece of aluminum and after 24 hours it just about impossible to scratch, and the paint takes two weeks to harden 100%, although the bike can be ridden after just a few hours......But I'd stay out of the gravel for a week or so......
Here's the paint and it's available in lots of colors ( I used Titanium to match the engine on the 07 Wee)at;
www.midwayusa.com
Lauer DuraCoat Firearm Finish Titanium 8 oz
DuraCoat's unique combination of chemical and water resistance, adhesion and abrasion resistance, hardness and impact resistance are legendary. Available in standard matte or semi-gloss (HK) black as well as a complete list of colors to create your favorite camouflage finish. Finish can be applied to ferrous metals, alloys, synthetics, woods and more. No preheating or baking required unless desired. DuraCoat eliminates the problems typically found with many other heat cure finishes: Preheating and handling of hot parts, high curing temperatures, "orange-peel" and other inconsistencies caused by surface cooling or solvent evaporation during curing. Can be used to create special effects like texturing and shadowing. The dry film thickness can be varied from .25 to 1.5 ml. Additives such as prisms and flakes can also be used. DuraCoat needs to be applied with an airbrush, conventional automotive spray gun or a High Volume Low Pressure (HVLP) system.
Product #: 941104
Manufacturer #: DC878
Our Price: $29.49
Before:
After
Front fender is out being painted same color as the fairings...Stay tuned!
Roy B
Massachusetts
[url]www.rvbprecision.com[/url]
2007 Suzuki DL650 V Strom abs
2007 BMW K1200R Sport abs
2004 Honda VFR abs
2001 Moto Guzzi Rosso Mandello
[url]http://public.fotki.com/Rbertalotto/[/url]
rbertalotto is offline
post #2 of 12 Old 06-10-2007, 07:31 PM
Good find. I'm not a fan of the black wheels either. Too many black parts on my 05. I want to paint my wheels gold.
Yours looks good. Amazing how much lighter the bike looks without black wheels.
How much paint was required to do 2 wheels?
Let's go!
05 DL1000
Mountaintime05 is offline
post #3 of 12 Old 06-10-2007, 11:03 PM Thread Starter
8 0z...........I had enough left over to do the forks if I had wanted to, but since I wasn't prepared for this, I sprayed it all on the rims. You can buy the paint in 4 oz and 8 oz sizes.
Roy B
Massachusetts
2004 Honda VFR abs
post #4 of 12 Old 06-11-2007, 11:02 AM
Packa-strom's Avatar
How hard was it to paint the wheels... how long did it take?
I like the look A LOT...
Packa-strom is offline
post #5 of 12 Old 06-11-2007, 02:27 PM
What surface prep did you do? What did you use for a spray gun?
Let's go!
05 DL1000
post #6 of 12 Old 06-11-2007, 03:15 PM Thread Starter
Prep?
I cleaned them real good with Greased Lightning, followed by MEK (Methel Ethel Keyton)(sp?), and finally Alcohol. A light sanding with 220 grit, followed by another cleaning with MEK. (MEK is the solvent for the two part epoxy)
I did not demount the tires. I removed the cush drive and the brake rotors, masked everything off and sprayed them.
I used a Touch-Up gun I bought at Sears for under $50 with my small shop compressor. Nothing fancy.
Work relatively quickly as the epoxy dries in about 20 minutes at 70 degrees. But this is plenty of time to work. I did one wheel at a time. Cleaning my gun with MEK after each application. One coat covered fine. It seems real hard to get this stuff to run. You can lay it down relatively thick as it isn't dependent on air to dry, it dries with a chemical reaction no mater how thick...........DON"T LEAVE IT IN THE SPRAY GUN while you prepare the second wheel!
Have at it!
Roy B
Massachusetts
2004 Honda VFR abs
post #7 of 12 Old 06-11-2007, 05:01 PM
ClintK's Avatar
That looks cool, I'm thinking about doing the lime green.
04 V-strom 650
ClintK is offline
post #8 of 12 Old 06-11-2007, 05:15 PM
Like the Kawasaki green Strom at the Reno gathering. Was real neon. Kind of cool looking though.
"What can will go wrong".
07 V-Strom 650
03 Yamaha FJR 1300
Its loaded to the max.
FJR/V-strom trooper is offline
post #9 of 12 Old 06-11-2007, 05:31 PM
ClintK's Avatar
If they had neon blue, I'd do that.
04 V-strom 650
ClintK is offline
post #10 of 12 Old 06-11-2007, 06:02 PM
msheron's Avatar
Originally Posted by rbertalotto View Post
Prep?
Have at it!
Hope you used gloves when using MEK Methyl Ethyl Ketone............is a carcinogenic if handled over time. I deal with chemical clean-up's as a way of life and these chemicals even though bought at any hardware store are very dangerous through skin absorption.
Also used in making Methamphetamine. How do I know that?:mrgreen:
<a href="http://www.danasoft.com"><img src="http://www.danasoft.com/citysign.jpg" border="0"></a><p><div style="font-family:Arial,sans-serif;font-size:11px;">Sign by Dealighted - <a href="http://www.dealighted.com">Coupons and Deals</a></p></div>
msheron is offline
