Stebel install w/ pennytech bracket - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
post #1 of 10 Old 06-10-2007, 03:03 AM Thread Starter
The Golden Monkey's Avatar
This evening I finished installing my Stebel Compact Ear Destroyer. I had been puzzling over the best way to attach it inside the fairing, and finally decided to make a bracket from a piece of 3/4" x 1/8" aluminum bar I had laying around. Of course, the next day someone pointed out Pat Walsh's new bracket, which is pretty much exactly the same thing...
It would have worked a little better if the bar I had was an inch longer (for a more complete wrap around the fairing brace), but I think it'll be ok. Lock washers don't work when they're not bearing on a relatively flat surface, so I loaded up on the loctite. If I find it working loose, I'll just have to break down and make a new one.
I used the bolt and nut included with the horn to attach it to the bracket. I had to drill out the hole on top of the horn mount, since it was a little too small for the bolt. I also added a lock washer between the bolt head and the mount (the nut is captured in the mount, so it can't work its way loose).
The wiring is all pretty standard: 14ga fused power lead from battery to relay (velcro'd on top of the radiator), used existing horn leads for relay trigger. Heatshrink tubing on all the connectors, and some flexible plastic automotive conduit along the left side from underseat to the front top edge of the left "wing" of the gas tank. The ground is also 14ga, runs back from the horn through the conduit to the battery negative. One more electric farkle will justify fuse and ground blocks...
2010 Triumph Tiger 1050se
2009 DL650A - sold
2005 DL650 - dearly departed
The Golden Monkey is offline
post #2 of 10 Old 06-10-2007, 07:57 AM
Rjsurfer
I used the same location as you did but used some stainless hose clamps to attach it to the bar.
I just flipped the horn around 180" from your picture, one clamp on the top another on the bottom.....boy are they loud !
Ron W.
rjsurfer is offline
post #3 of 10 Old 06-13-2007, 12:04 AM
I separated the compressor from the horn. Mounted the horn to the right of the motor on a bracket made of 2"x1/8" aluminum bar. This bracket is fastened to the same mount as the voltage reg/rec, needed longer screws. The compressor is mounted under the seat, outside the right frame rail, about even with the battery. Used a SS hose clamp. Connected the two with a piece of 1/4" I.D. vinyl tubing.
When in doubt, gas it!!!
Tom-S is offline
post #4 of 10 Old 06-15-2007, 03:43 PM
Colin's Avatar
Especially when you have them in that megaphone of a fairing and pointed right at you
Colin is offline
post #5 of 10 Old 06-15-2007, 04:00 PM
Rjsurfer
I love my earplugs....The Strebel still gets through.
I don't leave home without them....
Ron W.
rjsurfer is offline
post #6 of 10 Old 06-15-2007, 04:50 PM
Heavy's Avatar
Neither will I....the Stebel or my ear plugs!
DL1000K6
Heavy is offline
post #7 of 10 Old 06-15-2007, 04:51 PM
whistler's Avatar
My solution to the Stebel's "directional" issue. Works well for me.
2019 Yamaha Tracer 900 GT (Annabelle)
2013 Suzuki V-Strom DL650 (Juliette)
2013 Yamaha FJR 1300 (Rachel)
2008 Suzuki Bandit 1250S (Fiona)
2006 Honda VFR800 (Jenny)
2005 Suzuki V-Strom DL650 (Hannah)
2003 Honda Shadow Sabre VT1100 (Veronica)
whistler is offline
post #8 of 10 Old 06-16-2007, 07:21 AM
tmcgee's Avatar
...or you can just add more horns.
tmcgee is offline
post #9 of 10 Old 06-16-2007, 10:37 PM
whistler's Avatar
Can you imagine two Stebels? Wow, what a racket that would make! Interesting . . .
whistler is offline
post #10 of 10 Old 06-17-2007, 11:44 AM
no need to imagine....this guy put 2 on a R1150RT.
http://www.mklsportster.com/r1150rt/hornvideo.avi
RubberDown is offline
