How many have bent/formed 'plexiglass'? - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
post #1 of 9 Old 06-07-2007, 10:18 AM Thread Starter
I'm wanting to make a homemade shorty windscreen. I *think* it should be easy enough to heat the plexiglass / acrylic in the oven and get it formed to my desire shape. Anybody have any tips on this? One thing I heard regarding heating acrylic in your oven is it gives off flammable gases which could cause a... well you know what I mean.
TIA
Scott
Old bikes:
2001 Kawa Z750S
2002 Honda VFR
2006 DL1000
Akrapovics
Zega 41L Bags
Hyperlites
Stebil Horn
Givi Tall Windscreen
Hella FF100 Fogs
Fuse Block
Hepco Becker Engine Guards
Suzuki Center Stand
"Man Has Not Evolved One Iota From the Slime That Spawned Him!"
zenwhipper is offline
post #2 of 9 Old 06-07-2007, 11:34 AM
I attempted to reshape the Suzuki tall screen. It ended up in the trash.
Getting the stuff warm enough to shape is easy. The trouble is that the whole screen is now pliable and I only wanted certain places changed.
With a jig I probably could have done what I wanted.
Suzuki euro sport screen is the answer.
I see you're in the NW. I have my cut down stocker if you wanted to try it.
Let's go!
05 DL1000
Mountaintime05 is offline
post #3 of 9 Old 06-07-2007, 12:13 PM
Jblk9695's Avatar
You might want to consider using Lexan and not plexi. Lexan is a lot tougher and less prone to shattering when hit. Easier to cut and form too. Just my 2 cents.
Jerry
Second childhood, heck, I'm still in the first. 72 going on 25
Added an 09 Yamaha FZ6 for my birthday
Sold the FZ6 and got a Triumph Tiger 800
Now have a Triumph Bonneville and an 09 Wee
Retired and lovin it
1945 Wife
Jblk9695 is offline
post #4 of 9 Old 06-07-2007, 01:11 PM
Colin's Avatar
Somewhere, on this forum I think, there was a post with instructions on how to make your own screen using Lexan. There were a few things to watch for. Mostly temperature as I recal.
Try a search here and perhaps the other forum.
Somewhere I saved the instructions so I could make one last winter. Now where did I put those instructions...
Colin is offline
post #5 of 9 Old 06-08-2007, 07:36 AM
dungee's Avatar
Send a message via MSN to dungee
I'm not sure if what you call "Plexiglas" is the same as what we call "acrylic" but I have made a screen from 6mm thick black acrylic. Having done this I would probably use 4mm acrylic if I made another.
Here's how I made it, started with a square sheet aprox the same size as the std screen that would fit in the oven on an angle, I made mine a little wider the the original.
Removed the std screen, placed it on the bench edges down but elevated on a block of wood.
Add a few layers of newspaper on top to protect it from the heat.
Remove the adhesive protecting paper from the acrylic and pre heat the oven to 170 degrees Celsius. Place the acrylic into the oven for 10 minutes or until it has reached 170 degrees. It will be flexible like a sheet of rubber at this temperature so be careful handling it.
Remove it and place it on the original screen, this will mold it to the correct shape. Once cool it will retain the curve from the original screen.
I then stuck the protective paper sheet back on the acrylic and used the original screen for a template to mark the holes and shape.
Cut the screen with a fine tooth jigsaw, be patient and work slowly. Select two drill bits, one small for a pilot hole and one the correct size. Blunt both on the grinder so the edge is not undercut, this will prevent the drill from biting into the soft acrylic and cracking it.
I used an orbital sander on the edges and finished off with some fine wet and dry paper.
All this cost me $40 and two hours work. An no more buffeting :-)
I'll take some pics and post them this weekend
2006 Suzuki DL1000
2003 BMW R1150RS
1991 BMW R100RS
1980 Suzuki GSX750E
1979 Yamaha DT175
1973 Yamaha RD350
1972 Yamaha TD3-350
1978 Yamaha XS750
1974 Honda CB500
1976 Honda TL250 (My First Bike)
Reach in and pull out the big ones
dungee is offline
post #6 of 9 Old 06-09-2007, 12:55 AM
dungee's Avatar
Pictures of acrylic shorty screen.
2006 Suzuki DL1000
2003 BMW R1150RS
1991 BMW R100RS
1980 Suzuki GSX750E
1979 Yamaha DT175
1973 Yamaha RD350
1972 Yamaha TD3-350
1978 Yamaha XS750
1974 Honda CB500
dungee is offline
post #7 of 9 Old 06-09-2007, 01:43 AM
Destro's Avatar
That custom job is outstanding!
DESTRO
Destro is offline
post #8 of 9 Old 06-10-2007, 07:07 PM Thread Starter
Thats just about what I'm looking for. Thanks for post and instructions.
Scott
Old bikes:
2001 Kawa Z750S
2002 Honda VFR
2006 DL1000
Akrapovics
Zega 41L Bags
Hyperlites
Stebil Horn
Hella FF100 Fogs
Fuse Block
Suzuki Center Stand
post #9 of 9 Old 06-11-2007, 07:02 AM
garandman's Avatar
A few general comments.
Plexiglass is a trade name for Acrylic. HD has thin acrylic sheets: plastic supply houses will have many sizes and thicknesses, including cut pieces that may be usable for a screen. It's probably the most common material used because it's clear, easily formed, and scratches can be buffed out. But it is fairly brittle, especially at extreme low temps.
Lexan is the GE trade name for Polycarbonate. Polycarbonate has much higher impact resistance than acrylic and better temp resistance. But if it is scratched you cannot buff out the scratches. So it is a great choice for a low screen or a solid color one like the one above, or if you are careful for a taller screen.
The other material that seems to used for windscreens is Polyvinyl Butyrate, also sometimes called just Butyrate. It is clear but feels flexible. I had a BMW windshield on my old R65 I believe was Butyrate.
If you are using the original windshield as a pattern, trace it with paper then make the new sheet a little bigger to allow for the curvature.
When drilling any plastics, the standard angle for a drill bit does not work well and will often crack acrylic. Either start with a timy pilot hole and use a progression of sizes, buy plastic bits, or grind the tip of your drill: you can find recommended angles on the web.
Drill all through holes a little oversize to allow clearance for the screw, as otherwise cold temps may cause cracking.
Sand the edges until they are relatively smooth to prevent cracks. For a clear look, use a solvent to wipe the edge lightly.
garandman is offline
