This can be installed without removing the fairing.
I recommend removing the fairing in a safe and tidy manner.
WARNING:
If you are careless you can trap two things when mounting the radiator guard:
1) The wiring harness for the fan thermostat on the port side of the radiator front.
2) The overflow hose from the coolant header tank on the starboard side of the radiator front
I had trouble removing the fairing and so completed the job using my best gynacological skills to manouver two hands, a ratchet and an Allen key in limited space. Not recommended.
WARNING:
