Re-worked mufflers - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
post #1 of 4 Old 06-03-2007, 06:37 AM Thread Starter
Laava's Avatar
Re-worked mufflers
Has anyone pulled the stock mufflers out and removed the std core to put in a freeflow type section? Reason I'm asking is that I would like to free up horses but want to keep the muffler shields on. Long story.
[Oh.... and Heavy, I'm still getting around to doing that double bearing thing to the sprocket carrier! Just for you!]
L4 DL1000 Black Strom No3
Laava is offline
post #2 of 4 Old 06-03-2007, 08:53 AM
Heavy's Avatar
Oh, great!
Is he really talking to me?....double bearings?....huh?....should I be excited or scared?
DL1000K6
Heavy is offline
post #3 of 4 Old 06-04-2007, 06:59 AM
No longer riding.
handyhiker's Avatar
I drilled the center with a hole saw. Found one to just fit down the pipe from the back, and drilled through the baffel. A very slight noise increase but did make the bike run leaner. After the YOSH all is good.
Totaled on June 9 2012 08 Victory Vision Tour Premium.
No longer riding due to injuries on June 9 2012.
handyhiker is offline
post #4 of 4 Old 06-04-2007, 10:36 AM
V1Vr's Avatar
This may help you. It's a 650 muffler not a 1K but I'm sure the innards are similar. Give you an idea of what your up against.
http://www.raceratb.com/austin/car/vstrom/muffler.htm
Blue DL650 k6
Better to remain silent and thought a fool than to speak out and remove all doubt, A. Lincoln
V1Vr is offline
