Please help! (Installing SW-Motech crash bars) - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
post #1 of 7 Old 06-02-2007, 11:10 AM Thread Starter
I am in the middle of installing new SW-Motech crash bars on my '06 Wee. I can not loosen the engine mount bolt, do I need pneumatic tools for this? Is there something I need to do prior to loosening this bolt? Is the engine going to come crashing down once I pull the bolt out? I have some Tim "the toolman" Taylor tendencies when I try to do something myself. Could someone please give me some advice. Thanks a bunch.
Thomas
In order of ownership:
2005 Yamaha YZ-450F
2005 Suzuki DR-Z400SM
2006 Suzuki DL-650
Stromas is offline
post #2 of 7 Old 06-02-2007, 11:50 AM
That bolt took quite a bit of force to remove on my '07. You may need to arrange your wrench so that you can put your weight into turning it, or hire a gorilla . Don't worry about the engine moving--it won't go anywhere while you have the bolt out. Good luck!
cra1g is offline
post #3 of 7 Old 06-02-2007, 12:00 PM
Stromas, have you tried a "cheater bar"? It's nothing more than a length of metal pipe that slips over the wrench handle and gives you more leverage.
W.
Strombock is offline
post #4 of 7 Old 06-02-2007, 12:03 PM
The left side needs to be held with one wrench while the nut on the right side is loosened. I found it to be an easy two pipe job.
post #5 of 7 Old 06-02-2007, 09:36 PM
cmosentine's Avatar
It is strange that some people have trouble with this while others do not. I just put the same on my 1000K6. Mine came right off. Use a cheater bar or bigger wrench.
[U]Chris Mosentine [/U]
2008 HD FLSTF
Previous - 2006 Suzuki DL1000, 1993 Kawasaki VN750, Suzuki DL350, 1976 Yamaha DT400, 1977 Honda XR75.
cmosentine is offline
post #6 of 7 Old 06-03-2007, 12:01 AM
Clever Title
I got it right off with 2 ratchets, one on either side, both with cheater bars. Straddled the bike and operated the ratchets from that position.
Guess I should have been wearing pants...
'86 Suzuki GS450L (redneck-farkled)
'79 Yamaha XS1100 (project bike)
'06 Suzuki DL650 (SW-MOTECH: centerstand, bellypan, crashguards) (3M reflective striping) (Powermadd handguards) (Nelson-Rigg saddlebags and tankbag)
iron_llama is offline
post #7 of 7 Old 06-03-2007, 12:52 PM
TinyBear's Avatar
No probs when i did mine but i turn wrenches for a living and am pretty large too boot so maybe that helped. I used two standard mastercraft 1/2 drive ratchets and off they came.
2017 Suzuki V-Strom 650 XTSE
2010 Yamaha TW200
2016 Polaris Sportsman 450HO
2004 Suzuki Ozark 250
TinyBear is offline
