Horn install - how do I remove the fairings? - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
post #1 of 4 Old 05-28-2007, 04:05 PM Thread Starter
Yall-
I'm installing me Stebel Horn - and I want to remove the side fairings (not the upper black fairing that comprises the windshield / gauges assembly). Does anyone have any tips on this? Any links I could use to help me. Seems easy enough - yet, she's still together .
Tanks
Mates
Old bikes:
2001 Kawa Z750S
2002 Honda VFR
2006 DL1000
Akrapovics
Zega 41L Bags
Hyperlites
Stebil Horn
Givi Tall Windscreen
Hella FF100 Fogs
Fuse Block
Hepco Becker Engine Guards
Suzuki Center Stand
"Man Has Not Evolved One Iota From the Slime That Spawned Him!"
zenwhipper is offline
post #2 of 4 Old 05-28-2007, 04:49 PM
Colin's Avatar
There are a couple of sort of hidden screws in the little grill things. Phillips tip screwdriver to remove. There are also a couple of those black pop rivets on the underside above fender as I recall. Push the center of the rivet to release.
I am also assuming you removed the crome hex head bolts on fairing itself and on the strip between fairing and dash?
A good source of this stuff is the shop manual. There is a link several places in the forum but I can not fid it just now.
Colin is offline
post #3 of 4 Old 05-28-2007, 07:57 PM
Yep. Removing the chin piece first is the key. Its removal provides access to the screws holding the fronts of the side panels.
post #4 of 4 Old 05-29-2007, 04:01 PM
mcdstrom's Avatar
Be sure you know where all the screws and rivets come from. I thought I was being very careful but ended up with an extra after I got everything put back on. I should have taken pictures or at least written some notes.
2009 DL650A Grey
2004 DL650 Blue - sold
Long ago TC-90
mcdstrom is offline
