chain tensioner - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
post #1 of 5 Old 05-27-2007, 09:17 PM Thread Starter
roninwva's Avatar
chain tensioner
Has anyone tried to install a chain tensioner on their Wee? Seems like it would keep the chain at a constant tension and give better chain life.
So many roads so little time!
CMA
PGR
HOG
91 harley dresser
04 Kodiak 450
06 DL650 wee-strom
roninwva is offline
post #2 of 5 Old 05-30-2007, 02:24 PM
I do not think you need a chain tensioner these days .Modern good quality X or O ring chains with a lubeman should be all you need, well lubricated chains do not " stretch" as they do not wear nearly as fast. Chains that are over tight are a bigger problem ,losse is better than tight.Clean your chain, spend the money on a lubeman set it up adjust your chain and RIDE.
This is provided your sprockets are aligned correctly.
Graham Downunder
graham downunder is offline
post #3 of 5 Old 06-02-2007, 11:37 PM
ClintK's Avatar
Question
what's a lubeman?
ClintK is offline
post #4 of 5 Old 06-03-2007, 08:58 AM
Heavy's Avatar
Originally Posted by ClintK View Post
what's a lubeman?
He's leading you astray.
Do a search for Loobman...be sure to have a free hour to read it all.
DL1000K6
Heavy is offline
post #5 of 5 Old 06-06-2007, 09:15 AM
Stromtrooper for Life Godspeed Jay
JayR's Avatar
I'll send you a Loobman if you pay postage and $5
Not overly fond of my Loobman. Keeps slipping when out on wash board gravel roads, and still have to put it on the centerstand to clean the chain with a grunge brush to get the dust and dirt off anyway. So may as well spray the chain when I am cleaning it.
Looks like a good idea, and worked fine on smooth roads.
Global Warming, because a populace on foot is easier to control. They can take the keys to my fire breathing, CO2 belching, Strom and other cylinders from my cold dead hands.
2006 Suzuki DL1000
JayR is offline
