Need New Handlebars - want to use stock bar-ends and handguards - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
post #1 of 17 Old 05-24-2007, 08:23 AM Thread Starter
garry's Avatar
The stock bars on my Wee have too much sweep. After spending six days and nearly 2200 miles on the Wee, I'm betting the back cramps I had are due to the funky shaped stock bars putting my arms/wrists at a weird angle. I'm sure I would have been more comfy on my sportbike than the Strom.
So, who makes 7/8" bars with lots less sweep that let me re-use the stock bar ends and Suzuki hand guards? I've searched and been looking online, but haven't found a definative answer.
Will the cheap steel Moose Racing bars accept the OEM barends and handguards?
Thanks!
2007 KTM 950 SM-R
2004 Suzuki DRZ400S
2005 Kawi ZX-6R [b]FOR SALE[/b]
[URL]http://www.motoroads.net[/URL]
garry is offline
post #2 of 17 Old 05-24-2007, 08:26 AM
GrayStrom's Avatar
I don't know about the handguards, but I have moose CR-Lo on mine with the stock bar ends. I am looking into putting superbike bars on mine because the straight motoX bars are making my hands fall asleep. I need something with a little bend at the ends.
K7 DL650
"It is invariably saddening to look through new eyes at things upon which you have expended your own powers of adjustment."
-a former member of the "bigger bike is better" club?
GrayStrom is offline
post #3 of 17 Old 05-24-2007, 09:13 AM
Heavy's Avatar
I put the MSR, ATV-High bars on my Strom and I'm very pleased with them. They were really cheap (<$20.00) and everything bolted up nice and easy. They have a little more height and less pull-back. All and all, a good purchase.
And don't let the expensive aluminum handlebar snobs tell you otherwise.
DL1000K6
Heavy is offline
post #4 of 17 Old 05-24-2007, 09:18 AM
fl_strom's Avatar
Garry,
Have you tried rotating them backwards about 10 degrees?
Just a thought.
Fl_Strom
~ He ain't Heavy, he's our curmudgeon! ~
06 DL1000 - Candy Sonoma Red
06 KLX331S - Lime Green
04 KLR650 - Aztec Red
74 CB350F - White - at least now
fl_strom is offline
post #5 of 17 Old 05-24-2007, 10:01 AM
fl_strom's Avatar
If you don't want to go the expensive route of the MSR bars, there is always the Moose for $16.99!
Here's the specs:
ATV-Hi:
Pullback - 3.2 in.
Width - 32.5 in.
Rise - 5 in.
Base - 6.5 in.
4Trax/Quad:
Pullback - 3.8 in.
Width - 29.2 in.
Rise - 4 in.
Base - 6.5 in.
Fl_Strom
fl_strom is offline
post #6 of 17 Old 05-24-2007, 10:15 AM
Heavy's Avatar
I found my MSR's for under $13.00.
DL1000K6
Heavy is offline
post #7 of 17 Old 05-24-2007, 01:37 PM
Ogre_FL's Avatar
I installed the Moose CR-Hi on my DL650 with the factory hand guards and bar ends.
They are flatter, lower & wider than stock.
I did have some issues with a very limited range of adjustment that kept the guards off the fairing at full lock.
I added small rubber bumpers to the steering lock tabs, lost just a bit of steering lock, but gained enough adjustment that I am comfortable with the bar placement.
I got them for $11.99 here:
http://www.motorcycle-superstore.com...656&Division=6
*edit: This may be a better pic of the bars
Ogre_FL is offline
post #8 of 17 Old 05-24-2007, 02:52 PM Thread Starter
garry's Avatar
Garry,
Just a thought.
Which direction is "backwards"? Toward the rider or away from the rider? No, I haven't played with that since it's the bend in the wrists that is annoying. Rotating would mostly affect height and distance from the rider, no? A little more height would be good too since the stock bars are kinda low when standing over bumpy terrain.
2007 KTM 950 SM-R
2004 Suzuki DRZ400S
garry is offline
post #9 of 17 Old 05-24-2007, 06:48 PM
Maniac's Avatar
Don't hate me for asking, but why, if going to the hassle of replacing the bars, don't you use some handlebars that will withstand drops/crashes? Just food for thought. YMMV.
Ian S. -- Temecula, CA
04 KLR685 -- 09 F800GS --
Moderator @ [url]www.klr650.net[/url]
[url]www.pbase.com/ischoenleber[/url]
Maniac is offline
post #10 of 17 Old 05-24-2007, 08:56 PM Thread Starter
garry's Avatar
Because I'm a cheap bastid that is still seriously thinking of just bending the stock bars with a big steel rod to reduce the sweep. I don't like the idea of spending the money for cheap bars and grips let alone expensive ones that don't let me re-use the OEM handguards and barends I already own.
2007 KTM 950 SM-R
2004 Suzuki DRZ400S
garry is offline
