Wiring HELP! - license plate light - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
post #1 of 3 Old 05-16-2007, 10:09 PM Thread Starter
Unhappy Wiring HELP! - license plate light
Yall-
I performed a fender-ectomy about a week ago. Part of this was removing the license plate light to raise the license plate up on the rear fender. When I removed the LP light - I just clipped the two wires leading to the light assembly, about 3 inches from the light assembly. I taped the ends and that was that. I now am adding a Fuse Block and want to run the relay switch power off of the license plate light wiring. Well- there seems to be no power running through the license plate light wires. I'm not sure what's going on. I have the tail-light / brake light working - so its not a fuse issue. Also - its a bit odd to me - but the two wires 'powering' the license plate light are not color coded - they are both black. I think one shoud be Gr and the other should be B/W.
Anyone have any ideas?
Mucho Gracias
zw
Old bikes:
2001 Kawa Z750S
2002 Honda VFR
2006 DL1000
Akrapovics
Zega 41L Bags
Hyperlites
Stebil Horn
Givi Tall Windscreen
Hella FF100 Fogs
Fuse Block
Hepco Becker Engine Guards
Suzuki Center Stand
"Man Has Not Evolved One Iota From the Slime That Spawned Him!"
zenwhipper is offline
post #2 of 3 Old 05-16-2007, 10:15 PM
SCraig's Avatar
One side will show no voltage because it's connected directly to the battery negative terminal. The other side should show +12 volts but will do so only when the light is on, obviously.
The wire going directly to ground should be black with a white trace. The one that is hot should be, as you indicated, gray.
I did the same thing on mine but I don't recall what the exact colors were.
Scott Craig - Nashville, TN
SCraig is offline
post #3 of 3 Old 05-16-2007, 10:45 PM Thread Starter
ah ha
Found it. The two-wire connector plug had come undone. Presumably, when I had been yanking on it to cut the wires. Now I just got put the tail assembly back together.
zw
Old bikes:
2001 Kawa Z750S
2002 Honda VFR
2006 DL1000
Akrapovics
Zega 41L Bags
Hyperlites
Stebil Horn
Hella FF100 Fogs
Fuse Block
Suzuki Center Stand
