Light Modulator question - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
post #1 of 24 Old 05-13-2007, 09:39 PM Thread Starter
docsporseen's Avatar
Send a message via Yahoo to docsporseen
Question Light Modulator question
Okay, let me get this out there up front. I'm colorblind and have avoided wiring at all costs. I used to install car stereos by fuse - if it blew, I'd try another wire (Only on my own car, of course). I've looked at the wiring diagrams for the taillight on the Wee's, and they label the wires as being grey, black, and white... simple enough. My question is, which is the brake "trigger" and which is the ground? The headlamps (Have a modulator on the way for those, too) seem like they'll be pretty simple. Any advice on this would be appreciated. I've already decided the extra work in "disassembling" the tail end will be worth avoiding headaches trying to get to the wiring. Thanks, kids!
"When I want your opinion, I'll give it to you" Author unknown (But a complete bastard!)
Navy Hospital Corpsman 1st Class, stationed in Camp Pendleton. 2007 DL650, now belongs to State Farm after my wreck on 17 January 2009. Proud owner of about a pound of titanium and steel in my left knee after the accident.
docsporseen is offline
post #2 of 24 Old 05-13-2007, 09:50 PM
SCraig's Avatar
The schematic I have shows the brake / tail light wires as being gray, black with a white trace, and white with a black trace. The one that is white with a black trace goes to the brake light switch.
I did remove the rear fender to install mine. Once you figure out how it only takes about 5 minutes. Remove the luggage rack (4 10mm bolts). A couple of pop-rivets on each side and one screw at the front to remove the two body panels (that have the "DL650" stickers on them), one hex-bolt on each side at the rear of the fender. Pull the fender back and there is a wiring connector on the left side. Disconnect it and the whole fender will come off.
Scott Craig - Nashville, TN
SCraig is offline
post #3 of 24 Old 05-13-2007, 11:38 PM
Tail light hot is gray, brake light hot is white with a black stripe, and ground is black with a white stripe.
post #4 of 24 Old 05-13-2007, 11:55 PM
Night_Wolf's Avatar
Buy a simple test light :rolleyes: They are only a cpl bucks and when you hit the right wire it'll glow so you know it's hot
Type @ Ya'll Later
Night_Wolf
2007 DL650abs Wee Strom
VSRI 1083/MIG 2625
A Newfie & Damm Proud Of It
Night_Wolf is offline
post #5 of 24 Old 05-14-2007, 01:03 AM
Fatstrat's Avatar
I'm cheating, I gave my brake light modulator to the tech when I dropped my Wee off for its break in service Saturday. Am expecting a quote from them for the HL modulator tomorrow.
And I am an electrical engineer!
Fatstrat is offline
post #6 of 24 Old 05-14-2007, 04:28 AM
Installed a Back-Off brake modulator without tearing apart the tail section. Find the tail light wiring on the left side of the bike. Test light will determine which is brake, ground and tail light. The wiring is in a protective sheath. Mounted the Back-Off unit to a flat spot with supplied two sided tape and attached the wires according to instructions. All I removed was the seat and side cover. Piece of cake.
What kind of headlight modulator are you getting ??
05 / 650 in blue
88 / KDX 200 in green
81/82 DT 175 Yamahussies
78/ GT 750 water pumper
75/Suzuki 125 RV
water warrior is offline
post #7 of 24 Old 05-14-2007, 10:09 AM
Ground is Black/White, brake is White/Black and tail is Brown in the sheath. The color code only changes from brown in the sheath to gray aft of the tail connector.
post #8 of 24 Old 05-14-2007, 05:34 PM Thread Starter
Thanks, guys! Got the BackOff! brake modulator in-hand. I'll install that this weekend. I have the Diamond Star headlight modulator coming in the next week or so. I will be seen, dammit!
post #9 of 24 Old 05-14-2007, 06:39 PM
LarryB's Avatar
I'd love to hear some hints, tricks, or gotchas associated with the Diamond Star installation. I'm planning on adding one of those too. One of the instructors at the MSF class had a headlight modulator on his Triumph and it was damn irritating, but impossible to overlook. I want one.
Edit... the modulator, not the Triumph.
[I]If you're not moving forward, you're probably in somebody's way![/I]
Current ride:
2006 Yamaha FJR1300AE, Cerulean Silver
2005 Suzuki DL1000, blue - sold
LarryB is offline
post #10 of 24 Old 05-14-2007, 06:45 PM Thread Starter
I ordered the dual-headlight kit for it, but I'm really thinking about just doing one so it's not quite so annoying to other drivers.
