OEM vs. SW-Motech centerstand bottoming - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
post #1 of 16 Old 05-13-2007, 08:57 PM Thread Starter
tmcgee's Avatar
I had a SW-Motech centerstand on the K5 650 that I just traded. Never had any issues with it other than bottoming on the thing once a month or so.
I'm planning to buy another centerstand for my K7 and want to know if any of you folks have bottomed the OEM stand.
tmcgee is offline
post #2 of 16 Old 05-13-2007, 09:14 PM
i have heard that the motech stand bottoms easier than the OEM. all i can say is i'm delighted with my OEM stand. it deploys very easily and i've never touched pavement with it while cornering.
TouringDude is offline
post #3 of 16 Old 05-13-2007, 09:32 PM
Stalky Tracker's Avatar
+1 on the OEM centerstand. Works fine for me.
2006 Suzuki V-Strom DL650K
1986 Honda Shadow VT700C
1974 Suzuki TM-250
1965 Suzuki 80
Stalky Tracker is offline
post #4 of 16 Old 05-13-2007, 09:44 PM
cmosentine's Avatar
+1 for the OEM stand too. Plus is comes with this stupid feeler for the foot peg (which I tossed).
[U]Chris Mosentine [/U]
2008 HD FLSTF
Previous - 2006 Suzuki DL1000, 1993 Kawasaki VN750, Suzuki DL350, 1976 Yamaha DT400, 1977 Honda XR75.
cmosentine is offline
post #5 of 16 Old 05-13-2007, 11:35 PM
The latest SW stands have a higher crossbar. I've never bottomed my older model though. Then again, I'm 100lbs lighter than the 285 I've so often seen reported here.
post #6 of 16 Old 05-15-2007, 04:01 PM
I'm happy with the OEM stand -- stable and easy to use. I did screw the inch-long feeler into the left peg, but I haven't scraped it yet even though I have had occasion to use pretty much all of the tire leaning in that direction. I'm not exactly bold when it comes to aggressive cornering, though, so I cannot represent (a) how much further I could lean before scraping the long feeler peg, (b) how much further I could lean before scraping the hard bits of the OEM stand, and (c) how much further I could lean before running out of tire.
650VTwin is offline
post #7 of 16 Old 05-15-2007, 04:28 PM
That thing you tossed is the first thing to scrap on the left side.
I too tossed mine.
absdl650 is offline
post #8 of 16 Old 05-15-2007, 04:58 PM
With the long feeler, you get a warning as the footpeg scrapes, vibrates and starts to lift. Without it, the first thing that happens is the sound of the centerstand lever scraping. Very shortly following that, if no corrective action is taken, the rear wheel loses traction and you are sliding across the road. Just so you know.
post #9 of 16 Old 05-15-2007, 05:12 PM
it takes a pretty big hit to lever the tire off the road. more likely that you will gradually grind down the deploy tang on the centerstand.
the beauty of big dual-sports like the v-strom is that they are so high off the ground it is pretty hard to scrape (unless, of course, you lower the bike). and if you ARE routinely scraping, you are either:
1) a much better rider than i am
2) on a fast track to a new set of plaster boots
post #10 of 16 Old 05-15-2007, 06:43 PM Thread Starter
tmcgee's Avatar
The initial question was definitely about bottoming as opposed to scraping. Potholes, bumpy roads, speedbumps, etc.
tmcgee is offline
